Db19 Posted September 8, 2013 Share Posted September 8, 2013 Hi Folks I'm looking for some knowledge on the difference between different wing mirror Mk's. My missus had her drivers side wing mirror whacked off by some ignorant/inconsiderate (insert expletive here). I recovered most of the parts and I have since discovered that you can't replace single items within the unit so I'm resolved to getting a new unit. I've looked on eBay and seen a few but there seems to be some discrepancies between sellers descriptions. As far as I can tell she has a Mk4 style mirror (2008-2011 - with indicator strip on rear) but some items look identical to hers and are listed as Mk5? Does anyone know if there is a difference between Mk's or has an item possibly been listed incorrectly if it looks identical? Tbh I've also seen the same mirror listed as a Mk2 2008-2011! Car is a 2011 plate. Cheers for any help! Db19 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 8, 2013 Share Posted September 8, 2013 The MK system generally used is not official and Ford themselves work by the manufacturing year. By rule of thumb MK1 was 98-late 02, MK1 facelift (1.5) was late 02- late 04, MK2 was late 04-late 07, MK2 facelift (2.5) was late 07- late 11, MK3 11-. MK 1 and MK1.5 use the same mirrors and the same with MK 2.5 and MK3, the MK 2 mirrors will only fit a MK2. Quote Link to comment Share on other sites More sharing options...
Db19 Posted September 8, 2013 Author Share Posted September 8, 2013 Thanks Stoney Sounds like the Mk3 (which looks identical and is listed as a Mk5) will fit then as the missus appears to have a Mk2.5. Cheers for help. Db19 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 8, 2013 Share Posted September 8, 2013 One thing to bear in mind though is the mirrors are the same but knowing Ford they may have changed the wiring connectors just to be a pain. If you search for a mirror rated 08-11 then you'll be much safer. Quote Link to comment Share on other sites More sharing options...
