golligy
Endura De Fuel Pump Issues
Hi
A slightly different problem from the norm possibly coming up :huh: I have a endure de engine with the lucas fuel pump fitted. The problem I have is it was fitted in my boat but removed for repairs, I have now re-fitted the engine but couldn't get it to run unless using easy start and only for a second or so. After further inspection I found that there is a multi plug with 3 pins connected to the fuel pump. I guess one wire is for the fuel stop soleoid one earth and not sure on the other?? So the problem as I don't have the whole wiring harness is there any way if knowing which pin relates to what?
Thank for any advice in advance..
