Chris Chopper Posted September 13, 2013 Share Posted September 13, 2013 Hi I need help installing a replacement heater select cable on my 2007 zetec focus 1.6 I have the cable I can remove the end nearest to the control panel but I can't see how to get to the other end can anyone please help? Quote Link to comment Share on other sites More sharing options...
johnH Posted September 13, 2013 Share Posted September 13, 2013 if you remove the glovebox, and fusebox located behind and the mount. you have some access to the blower motor and flaps i beleive. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 13, 2013 Share Posted September 13, 2013 Do you mean the thin wire that controls the temperature or the spring cable with the green ends? If the green ended one then the rear connector just pulls out, there is a small plastic clip on the end but is a gripper type and just pulls clear. If it's the thin wire then as stated above the cable goes down to the heater matrix and connects behind the centre console/glovebox. Quote Link to comment Share on other sites More sharing options...
Chris Chopper Posted September 13, 2013 Author Share Posted September 13, 2013 I see the diagram but it only shoes the top end I can do all that at the moment, I have removed pretty much everything that I can to gain access to the area but still I can't reach the end, There is a large ish triangle ish shaped metal plate that looks to be holding some things in place I'm not sure what its holding together but it seems to be in the way any ideas? I can't believe that this one part is so hard to reach and I'm really hoping that I don't need to go to the main dealer although I might have to just let my wallet take the hit. Any more diagrams or advice please Quote Link to comment Share on other sites More sharing options...
Chris Chopper Posted September 13, 2013 Author Share Posted September 13, 2013 PS Where did you get the diagrams from please? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 13, 2013 Share Posted September 13, 2013 PS Where did you get the diagrams from please?Microcat.There's a link somewhere, sorry I can't recall who shared it. I'll take a look in my Haynes later for you. Quote Link to comment Share on other sites More sharing options...
mgaking Posted September 13, 2013 Share Posted September 13, 2013 Microcat. There's a link somewhere, sorry I can't recall who shared it. I'll take a look in my Haynes later for you. This? http://eucatparts.com/?action=cat_ford Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 13, 2013 Share Posted September 13, 2013 That's the online basic version. There is a proper computer based programme like used by Ford. Quote Link to comment Share on other sites More sharing options...
