fiesta0007
Help Me To Rainstall Reverse Radar Backup System To My Fiesta
13 posts in this topic
Dear friends
iam new to this club and iam fron srilanka,
so i have a problem of instalation new reverse sensor to my ford fiesta 2012
so problem is what is the sorrect position for installing sensors ,
i saw various positiong in internet
so please help me
what is your recomandations
1.
or
2.
Both will work OK. The ones fitted lower down will be the easier to fit as you wont have to remove the bumper. The higher fitted ones look more like the factory fit but will be more difficult.
thankx friend
Once you get your parking sensors, they should come with instructions, detailing how far from the ground they should be. I think mine recommended 50-75cm. Too low or too high and it'll pick up too much and continuously beep or won't pick up anything and not beep at all.
I personally put a bit of masking tape where the sensors would go, dropped the back seats and hung out the back with someone else holding the sensors in position while a third person went round checking there were no blind spots before the bumper was drilled. We found that the only blind spot was rediculously close to the bumper, where the tow bar would be. But if there were any, it could be rectified before drilling.
thakx for replying and please tell me how can i identify correct wire color of reverse light
I have just fitted some to the Wife's Fiesta , same position as picture one , very easy to fit , just need to spend a little time measuring correctly from the center. Problem with the lower picture two would be two different colours to match.
i agree with you
so i think the best method is pic 1 \
by the way i have ford fiesta JA8 and please tell me how can i find color of reverse light wire\
Rather than guessing if you use a 12v tester you can insert into the plug of the rear lights and place in reverse gear and select ignition point two , (do not Start) , you will then be able to see which wire is live , when reverse is selected.
thankx'\
do u remember the colors of wire ?
i havent 12 tester so i have led 12v blub
i tested with car battery
so the positive (+) is the lower point of blub
the negative (-) is the round of the blub
could you please any one tell me is it wrong or correct
my electrical knowledge and English is too bad :(
sorry
dear friends
i glad to tell you today i installed rear sensors to my fiesta 2011
so i like to thanks for many friends help me to do this specially member
zahtar and others
thankx and best regards
what colour was the wire that you used in the end?
