Gary3059
Acetone
Can acetone be used as a brake cleaner ??
Yes but isopropanol would be better because acetone will eat rubber and your brake lines are rubber aswell as the boots on the caliper.
true, use the right products for the right job to make it easier.
I wonder does "vanish oxy powder" remove skid marks from the drive way too?
Or
If 45% sulphuric acid would save me sanding the paint of second hand plastic side skirts
Or
use cheap coke on the oil spill
sulphuric acid isnt strong enough, you need a flame thrower!
Sorry I meant 42% sulphuric lol its not possible to get higher sulphuric than 42%
Flame thrower would work, but neighbours may see flames and call fire brigade,
So I'll use methanol ;) burns with an invisible flame
just get a can of brake cleaner instead!
thats fair enough mate,i bought a 5 litre can a while back and have just run out but i have a 5 litre tub of Acetone and thought maybe it would work
so if not brake cleaner what other automotive use could it be good for then,just seems a shame having it sat there doing nothing
Hi Gary,
only reason i said get brake cleaner was that different chemicals react i different ways and I wouldnt want to see you get hurt. I've heard lots of stories where a different product ws used and due to heat/circumstances the person has ended up in hospital with burns or breathing difficulties. Always play it safe.
Whatever you end up using acetone on mate,
Definitely don't put it on any plastics because it will turn plastic white like stained glass,
I use it in work and got a drop on my safety glasses before,
Turned the plastic white inside,
I'd take the acetone out and burn some weeds in the garden or light some fires,
Because it kills plastic and rubber, its not really suitable for the car mate.
Hi Gary
Acetone is basically nail varnish renmover without a colurant, Perfactly safe to be used on nails ( keep the missus supplied for ages ).
Cheers guys,did dome googling last night and it looks like its good for cleaning paint brushes so dont have to buy any thinners for a while :D
I darnt put it near the mrs after the last time,
She has this habit of everything has to be given a sniff before she uses it,i mixed a solution of caustic soda to remove some anodising and she picked it up and sniffed it made her really ill for 24 hrs :(
