oil leak
2 replies to this topic
#1 psmk2
psmk2
    Member
  • New Member
  • PipPip
  • 11 posts
  • Ford Model: escort
Posted 08 April 2009 - 06:10 PM
hi,
i have a mk2 escort 1.6 xflow 711 block , it has started leaking oil from the front left hand corner of the head gasket, but the car is not over heating and the water in the radiator is clean also it idles lumpy or cuts out without choke, it seems to run fine with no smoke and sounds quite healthy The water in the radiator is clean and the oil isnt like baileys ...does this sound likehead gasket failure or should i be looking elsewhere for the oil leak
cheers
pete
Have something to contribute?
#2 squaddiefox
squaddiefox
  • New Member
  • 49 posts
  • Ford Model: fiesta flame
Posted 08 April 2009 - 06:29 PM
yep, don't drive it until you have had the head gasket sorted. what you are getting is oil probably leaking into a cylinder from one of the oilways.
which will cause the engine to run lumpy as it wont have the right combustion.
#3 psmk2
psmk2
    Member
  • New Member
  • PipPip
  • 11 posts
Posted 09 April 2009 - 07:15 AM
thanks mate,
i used a pressure tester on it and it has less pressure on the first cylinder where the leak is, so ill try and replace the head gasket at the weekend, ..judging by the haynes manual it seems a pretty sraight forward job
thanks again for you help
peter
Not what you're looking for?
