andystephens
62 Plate Transit Connect Problems
3 posts in this topic
Hi All,
My work van has developed the below problems
Central Locking not working
Electric Windows not working
Drivers Side speaker not working
Warning Saying driver side door open when its not
Indicators flashing faster when in use
Hazards randomly flashing
What could the problem be? Waiting to see if its still under warranty
If it's 2012 then it should still be under warranty. The fault could be anything from damaged wiring to a plug coming loose in the Fuse box. So check all connections in the fuse box are all secure.
Agree with Preee here, check the connections then run it to the dealer. Could be a disconnect in a harness somewhere, but as its under warranty, it should be Ford wasting the effort and not you!
