Byron95 Posted October 4, 2013 Share Posted October 4, 2013 In order to paint my trim ,"do i need a code to disconnect the radio?" or is simply disconnecting the battery good enough to stop my radio locking Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted October 4, 2013 Share Posted October 4, 2013 I take it your asking about a mk7?? If so take the gator plate off the gear knob by pulling it il, remove the heater and secrect tray flap, then remove the LCD display top face, you now have all access to the radio trim 4 bolts and pull up, just unplug the radio, no codes needed dont even need to remove the battery only 12volts next to no amps so your fine, paint the trim put all back togerher and plug in works fine, done this to 3 mk7s and worked perfectly same as before no codes needed Quote Link to comment Share on other sites More sharing options...
iNath Posted October 4, 2013 Share Posted October 4, 2013 My guide to removing the interior plastics: http://www.youtube.com/watch?v=j1eZvobdqvo And there's no radio code :) 1 Quote Link to comment Share on other sites More sharing options...
Byron95 Posted October 5, 2013 Author Share Posted October 5, 2013 Thanks. :) Quote Link to comment Share on other sites More sharing options...
Byron95 Posted October 9, 2013 Author Share Posted October 9, 2013 Where did you get those thingymabobs on your headlights they look slick and cant find em anywhere ? Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted October 9, 2013 Share Posted October 9, 2013 Who me or nath? Quote Link to comment Share on other sites More sharing options...
Byron95 Posted October 13, 2013 Author Share Posted October 13, 2013 you dan ? Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted October 13, 2013 Share Posted October 13, 2013 they are headlight eyebrows, here is the link, http://www.carparts-tuning.co.uk/Aerodynamic-body-styling/Eyebrows/CSR-cover-for-headlight-fit-for-Ford-Fiesta-MK7-all.html they take time getting to you tho :/ but are worth it :) mine are being painted the same colour as the car :) after removing headlight tints, i will post a pick once done :) 1 Quote Link to comment Share on other sites More sharing options...
