brianoz59 Posted October 7, 2013 Share Posted October 7, 2013 Hi guys looking for some help, every so often when driving, the temp gauge will drop down to cold, will still drive fine, but lose a little power and then pick up again, as soon as i switch it off and restart its fine again, sometimes it go to nearly cold but then climb back to normal temp, but eventually will go to show cold and fan will kick in. Any ideas or suggestions Quote Link to comment Share on other sites More sharing options...
DAN222 Posted October 7, 2013 Share Posted October 7, 2013 leave it unless its bugging you or your selling. Ours has been doing this now for 2 years. Its very inconsistent but we just leave it. Quote Link to comment Share on other sites More sharing options...
brianoz59 Posted October 7, 2013 Author Share Posted October 7, 2013 Cheers for that Dan, feeling better now, i thought it might be something to do with temp sensor, Thanks again Quote Link to comment Share on other sites More sharing options...
DAN222 Posted October 7, 2013 Share Posted October 7, 2013 Yes it is. Your right. I cannot guarantee without seeing its the same fault as ours... but it sounds the same. Ours sometimes just didn't work at all. Then after a couple of days worked fine. Its very inconsistent. But one thing about a Mondeo.. it keeps prodding along ;) If its bugging you take it to a garage - if not leave well alone and see what happens. Mines been doing it for 2 years nearly now. The aircon is on the verge, the tempretaure gauge is hit and miss and the rubbers for the back box need changing every 6 months... but the car keeps going. (Its now done 173,000 miles). Its not a car - its a tool. Quote Link to comment Share on other sites More sharing options...
stooge75 Posted October 8, 2013 Share Posted October 8, 2013 Coolant temp sensor,stuck stat,air-lock. Fairly easy to find out which one. You just leaving it the way it is? It will affect fuel consumption etc if it stays like that Quote Link to comment Share on other sites More sharing options...
FOCA Posted October 8, 2013 Share Posted October 8, 2013 Its a common ocurrence on the mk3 diesels - The temprature sensor is on metal of the head (its behind the waterpump/ power steering pulley) - this means it reads the actual head temprature, not the water temprature - the thermostat controls the water by opening an closing, diverting the coolant from the radiator, as it goes (slowly) through its close/open/close cycle, the temprature tends to go up and down The head cools/ heats at a different rate from the coolant, and as the thermostat controls the coolant, there can be a "mismatch" Also, the engine does not produce a lot of heat in normal use, and the heater tends to take a lot iof heat out of the system, if it takes more heat out than the engine produces, it will not maintain its temp - there is an electrical heater (3 element) built into the system before the heater, im not sure when this comes on, for how long (mabee just for warm up) - in artic countries the MK3 Mondeo has a diesel burner/ heater instead of the electric on we get The temp sender on the head is useful as if the water runs dry the exessive heat will be read by the sender, and the ECU backs off the fuelling (if the sensor was in the water if it ran dry it would not read it) + if the car has been sitting cooling for a while it reads the head temp and can adjust the fuelling accurately The engine is said to be "overcooled" and it is a common problem with mk3 Mondeo diesels If its really bad (running cool) and its not the electric heater elements it could be the second thermostat (small oil cooler thermostat on the waterpump housing) Quote Link to comment Share on other sites More sharing options...
stooge75 Posted October 8, 2013 Share Posted October 8, 2013 Just rectified exact same problem yesterday on some1's car.Replaced coolant sensor, oil stat,& water stat. Problem gone, now sits bang in middle of guage. Oh forgot to say that dodgy-oil stat can also cause overcooling issue(just noticed foca mentioned this lol). Actually the overcooled mk3's ive saw (4) have ALL had failing oil stats!! 1 Quote Link to comment Share on other sites More sharing options...
brianoz59 Posted October 8, 2013 Author Share Posted October 8, 2013 Thanks for that u guys, im having the coolant sensor fitted tomorrow, see if that sorts the problem, if not then will go ahead and do the other sensor and stat. Process of elimination, will keep u guys posted, Thanks again. Quote Link to comment Share on other sites More sharing options...
