jimmygixer Posted October 10, 2013 Share Posted October 10, 2013 My 2003 focus rear wiper no longer works. Before it died if i was to put a little pressure on the wiper it would then move, but not quite as fast as normal. How likely is it that the motors shot, or is there a fix? Quote Link to comment Share on other sites More sharing options...
msajohnson94 Posted October 11, 2013 Share Posted October 11, 2013 i would say it is shot the gears most likely worn down quite abit or the gear has come out of place best to take the back cover of and have a look inside. i do have a rear wiper motor fully working sitting around Quote Link to comment Share on other sites More sharing options...
jimmygixer Posted October 11, 2013 Author Share Posted October 11, 2013 i would say it is shot the gears most likely worn down quite abit or the gear has come out of place best to take the back cover of and have a look inside. i do have a rear wiper motor fully working sitting around Took it apart, its jammed tight with corrosion. I will have a go at releasing it. Cheers Quote Link to comment Share on other sites More sharing options...
msajohnson94 Posted October 11, 2013 Share Posted October 11, 2013 spray it with a bit of wd40 let it set in for a few mins might release Quote Link to comment Share on other sites More sharing options...
jimmygixer Posted October 12, 2013 Author Share Posted October 12, 2013 i would say it is shot the gears most likely worn down quite abit or the gear has come out of place best to take the back cover of and have a look inside. i do have a rear wiper motor fully working sitting around I attacked the motor today again with a bit of heat. The shaft was starting to move slightly, but it is that bad i needed to remove it for cleaning and regreasing. Was looking good but as i was thumping it out a bit the hole housing broke in half. So there goes that plan. I think my alternator is shot by the sound of it today also, just as im fitting new springs, what a !Removed! day lol What are you looking for your motor mate, im in N. Ireland? Quote Link to comment Share on other sites More sharing options...
msajohnson94 Posted October 12, 2013 Share Posted October 12, 2013 £10 for the motor and £10 for postage. if you want i can refurbish it for you before sending it out. i no its definitely working last time i checked. i also have an alternator for £15 good condition fully working. Quote Link to comment Share on other sites More sharing options...
