Ford Focus Mk2 Common Problems Thread
focus ford mk2 common problems
182 replies to this topic
#31 squiggly5297
squiggly5297
    Newbie
  • Budding Enthusiast
  • Pip
  • 8 posts
  • Name: Gary
  • Ford Model: Focus Titanium 1.6 TiCVT Duratec
  • Year: 2006
Posted 31 January 2014 - 09:08 PM
Sorry ended up taking it to a garage I trust and they told me the bearing in the alternator was either on its way out or seized, so they put a new alternator on to find that that wasn't the problem now they are looking at the water pump.
Sent from my SM-N9005 using Ford OC mobile app
Have something to contribute?
#32 DougF
DougF
    Newbie
  • Pip
  • 5 posts
  • Name: doug
  • Ford Model: Focus ST
  • Year: 2006
Posted 08 February 2014 - 11:36 PM
Reverse light switch failure (its on the gearbox). You'll know if you have the problem if your reverse light fails and the rear windscreen wiper doesn't do a sweep when you have the wipers on and engage reverse gear. Reasonably straightforward to fix I believe, but I had my local garage do it for me.
#33 Avon Tuning
Avon Tuning
  • Authorised Trader
  • 34 posts
  • Name: Gareth
  • Ford Model: Focus
  • Year: 2007
Posted 04 March 2014 - 06:04 PM
Really common problem we have seen on the 1.6 TDCI that come into us with DPF problems is that the rubber hoses that sit between the DPF and differential pressure sensor becomes brittle over time and breaks. If this happens the ECU can no longer monitor DPF saturation and the DPF will clog even quicker. If you have DPF problems worth checking these pipes first!
#34 catch
catch
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,306 posts
  • Ford Model: MK2.5 Focus 1.6 Titanium Petrol
  • Year: 2011
Posted 18 March 2014 - 11:11 AM
Best I add a post to provide a link to my 2010 fix for the "Water in Plug Ports Issue" with photos
[you know what they say better late than never]
Also see the link to my thread  on "Rusting Front Wheel Arches" [again with photos]
These where common faults on early build Mk2's on 05 and 55 plates. With a  possiblity of affecting some early 06 plates, as it's down to build date, not registration date.
Ford supposibly fixed both problems with revised washer jets [ I still advise silicone grease if you have this problem on later builds], They added plastic lower sill and lower wheel arch protectors on later builds, to eleviate rusting. That said,  I would still recommend fitting Ford mudflaps on the front wheel arches. Road grit thrown up by the front wheels acts like "shotblast" peppering your sills and in some cases lower door panels.
#35 artscot79
artscot79
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 21 March 2014 - 01:05 PM
agree with the above the revised jets dont solve the leak though and still require silicone sealant and the plastic gaurds help but the paint still gets stripped eventually sadly the cars design is the cause but the flaps slow the process a lot
#36 Captain Haddock
Captain Haddock
  • 130 posts
  • Name: Rob
  • Ford Model: Focus 1.6 Tdci Sport
  • Year: 2011
Posted 21 March 2014 - 01:32 PM
Front mud flaps are a must unless you like your paint being flayed off the lower leading edge of the rear doors and the leading edge of the rear wheel arches.  Oh and don't forget large amounts of tar spots (as if you could).
#37 bravo31zero
bravo31zero
  • 30 posts
  • Name: Rob
  • Ford Model: Focus 1.6 Zetec Climate Automatic
  • Year: 2005
Posted 22 March 2014 - 02:18 PM
Hi all new to group,
Just got a focus Zetec 1.6 on 55 reg
Found boot both sides ringing wet when collected and was told boot had been open during rain storm on Bristol st ford lot, they dried it out and I noticed 2 days later all wet again, took back to garage under warranty and they resealed boot hinges etc,
Found it wet today again argggggghhh.
I have removed both light clusters and cleaned body and found seals round light cluster screw hole plugs seem poor so sealed all round and in plug holes, round bottom grommet, and round wiring grommet.
Refitted and hopefully seems ok after last rain storm, but still checking, what I need to know please is where and how do I seal the boot spoiler as this is a common leak area too.
Thanks in advance rob
#38 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,548 posts
  • Name: Clive
  • Year: 2015
Posted 22 March 2014 - 05:11 PM
I have a guide to removing/refitting spoilers under my posts (available when viewed on a PC).
It shows where to seal against leaks.
#39 bravo31zero
bravo31zero
  • 30 posts
  • Name: Rob
  • Year: 2005
Posted 22 March 2014 - 05:43 PM
Thanks mate got it downloaded and will silicon mine if the sealing under lights didn't work today, pouring down now so hopefully still dry in boot lol
Great guide well done
#40 Stoney871
Stoney871
  • Super Mod
  • 18,548 posts
  • Name: Clive
  • Year: 2015
Posted 22 March 2014 - 07:04 PM
Glad to help.
#41 stevo398
stevo398
    Newbie
  • Pip
  • 2 posts
  • Name: Daniel
  • Ford Model: Focus
Posted 03 April 2014 - 07:58 PM
Hi
I have a 2008 Focus and my N/S headlight points to the floor I have tried to adjust manually but nothing happened.
Is it possibly broken or is there a common fault.
#42 bravo31zero
bravo31zero
  • 30 posts
  • Name: Rob
  • Year: 2005
Posted 04 April 2014 - 01:41 AM
Try taking bulb back out and refit in case not located correctly as this can alter the beam angle.
Check bulb glass is not distorted in metal holder again this will alter beam angle.
Try adjusting headlights up and down to see if motors are both working
#43 stevo398
stevo398
    Newbie
  • Pip
  • 2 posts
  • Name: Daniel
  • Ford Model: Focus
Posted 04 April 2014 - 11:17 PM
Thanks I'll give that a try.
Much appreciated,
Stevo
#44 bravo31zero
bravo31zero
  • 30 posts
  • Name: Rob
  • Year: 2005
Posted 05 April 2014 - 06:21 AM
Your welcome please update us once done ;)
#45 bravo31zero
bravo31zero
  • 30 posts
  • Name: Rob
  • Year: 2005
Posted 05 April 2014 - 06:32 AM
Found the problem :)
It was getting in behind light clusters, the plastic body plugs where lights screws go into had to remove light clusters bothsides, clean whole area as muck had collected under there and around plugs etc
Lifted rubber cable loom boot and temp sealed round it. Then temp sealed both upper and lower body plugs etc also there is a blanking rubber grommet near bottom so sealed that too.
going back into ford thursday so they can replace all body plugs which have a seal on which has deteriorated.
But at present and after two jet washes at work the old girl is still dry.
Part numbers :
1231409 upper body plugs and seals x 2 (L/R)
1231405 lower body plugs and seals x 2 (L/R)
1428727 light cluster screws x 4
approx £12 to get all parts from ford.
thanks Rob
Not what you're looking for?
