Ford Focus Mk2 Common Problems Thread
focus ford mk2 common problems
156 replies to this topic
#46 bravo31zero
bravo31zero
  • Budding Enthusiast
  • 30 posts
  • Name: Rob
  • Ford Model: Focus 1.6 Zetec Climate Automatic
  • Year: 2005
Posted 12 April 2014 - 07:02 AM
Went in yesterday and they replaced and carried out all the above so let's see when it rain.
Have something to contribute?
#47 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,806 posts
  • Name: arthur
  • Year: 2006
Posted 16 April 2014 - 12:48 AM
Refitting new plugs won't stop it the plugs have a foam seal this saturates and leaks only sealing them will solve the issue been there done that sometimes they work for a bit then leak again poor design plain and simple ford know this
#48 bravo31zero
bravo31zero
  • 30 posts
  • Name: Rob
  • Year: 2005
Posted 16 April 2014 - 03:47 AM
Ok thanks going to pop the lights off and double check they also sealed them as requested.
#49 Echorawks
Echorawks
    Newbie
  • Pip
  • 2 posts
  • Name: Samuel
  • Ford Model: Focus
  • Year: 2007
Posted 28 April 2014 - 08:40 PM
Hey guys new to fourm!
I have a 2007 focus, 1.6 petrol.  Noticed the power steering gets really heavy to the point where there is none at all when the engine isn't under load.
Am I to fear the worst that it's going to be a new power steering pump?
#50 SlawekBHX
SlawekBHX
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Slawomir
  • Ford Model: Focus 1.6TDCi Estate
Posted 28 April 2014 - 08:46 PM
Hello FordoManiacs
Couple days ago problems come out
I have Focus 2008 TDCi 1.6 Estate 58K
Lost power, engine chocking, engine shut off when acelerate on high revs during drive
Check today in local garage OBD2 and here we have list of faults:
P2459- Diesel particulate filter regeneration frequency
P0087- Fuel Rail Pressure Sensor
P1180- Fuel delivery system low
U0073- Control module communication bus off
U0416- Invalid data received from VDM
Please help if you had the same problems because the garage want today strip half of the car!
I really need my car to work
Please help
Thank you
#51 gavwer
gavwer
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 07 May 2014 - 03:08 AM
Very common problem also affects the 2.0l zetec my no.3 spark plug is completely corroded so can't change it atm
Sent from my GT-I9505 using Ford OC mobile app
#52 gaztdci90
gaztdci90
  • 206 posts
Posted 26 June 2014 - 04:08 AM
I have a 1.6 tdci goes in to limp mode above 70mpg or if driven above 3.5k red cog light with a ! In the middlencomes on,
#53 ian84
ian84
    Newbie
  • Pip
  • 2 posts
  • Name: ian
  • Ford Model: focus
  • Year: 2005
Posted 26 June 2014 - 02:45 PM
sods law!!!
paid my finance off in febuary and since then
  • coil pack - kaput
  • spark plugs - kaput
  • exhaust sensor - kaput
  • boot lock - kaput
  • 3 new tires
  • brake pads
  • brake disks
  • oil filter
and now low of power apart from that its an 05 focus saloon 60,000 and been a great car touch wood nothing else
#54 gaztdci90
gaztdci90
  • 206 posts
Posted 26 June 2014 - 06:26 PM
Coilpacks are reason I do not like petrol engines anymore I had a mk1 1 6 focus and it was ok for ages untill it spluttered then I replaced it and it kept doing it
#55 justinparry
justinparry
    Newbie
  • Pip
  • 4 posts
Posted 02 July 2014 - 09:44 PM
I have a 2009 ford focus zetec 1.6.. When i got it, it sounded fine, then it started to sound a bit tapperty. So i serviced it (new plugs. Oil/oil filter. Air filter) and it was still tapperty? I serviced it again today and no change! The engine splutters now and again aswell and it is idling at 900 and sounds like a diesel with the bonnet open! Is this common? And how do i fix it any ideas?
#56 Andy.B1971
Andy.B1971
  • 340 posts
  • Name: Andy
  • Ford Model: Zetec 1.6 TDCI
Posted 19 July 2014 - 08:22 PM
P0087/P1180 Fuel pressure low I would suspect a dodgy fuel filter.
my missus 56 plate 1.6tdci kept cutting out ONLY under heavy throttle and all sorts of odd codes popped up, it used to cut out saying power assist failure, I replaced the fuel filter and tickety boo all sorted , and been good the past 6 months.
The Diesel Really does require a regular fuel filter change and I keep to that now.
#57 luke19848
luke19848
    Newbie
  • Pip
  • 2 posts
Posted 27 July 2014 - 02:28 PM
Hi all I have a 08 ford focus 1.8 zetec wire off my air filter unit that runs to the injectors were can I get a new one thanks
#58 luke19848
luke19848
    Newbie
  • Pip
  • 2 posts
Posted 27 July 2014 - 02:30 PM
Tdci 1.8 zetec
#59 Son of Nod
Son of Nod
  • 32 posts
  • Name: Anthony
  • Ford Model: Focus Zetec
  • Year: 2006
Posted 06 August 2014 - 02:28 PM
Need to get this fixed too:
The heated windscreen can fail on one side either its a simple fuse issue to which there are 2 1 for each side or some cars under the scuttle panel have the electrical ribbon loose which gets rubbed by the wipers when in motion causing it to fail.
#60 dan meads
dan meads
    Newbie
  • Pip
  • 6 posts
  • Name: daniel
  • Ford Model: 2.0 tdci
  • Year: 2006
Posted 28 August 2014 - 08:34 PM
Hi can anyone help me pls I have 2006 2.0 tdci focus it keeps on going in to limp mode my mate put it on a snap on machine and it said particulate filter restriction ash accumulation bank 1 and particulate filter sensor "A" circuit if I buy a new filter will I need to top the fluid up and how do I do it? And do I need to remap or force regeneration even though it's a new filter? And do I have to replace the sensor or is the sensor failing just because it's blocked it's driving me mad would much appreciate it if someone could get back to me asap as I am goin to buy the new filter in a couple of days
Not what you're looking for?
Also tagged with one or more of these keywords: focus, ford, mk2, common problems
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
