Ford Focus Mk2 Common Problems Thread
focus ford mk2 common problems
156 replies to this topic
#61 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,403 posts
  • Name: Clive
  • Year: 2015
Posted 28 August 2014 - 08:44 PM
How much are you paying for your DPF?
New one on ebay for £120ish.
Eolys fluid top up is about £40 a litre plus garage time to do the job.
Is your DPF nacked or just clogged?
Surely a top up and forced regen is cheaper?
http://pages.ebay.co...4685579&alt=web
Have something to contribute?
#62 Andy.B1971
Andy.B1971
  • Budding Enthusiast
  • 340 posts
  • Name: Andy
  • Ford Model: Zetec 1.6 TDCI
Posted 28 August 2014 - 08:59 PM
just get the dpf gutted and remapped no more worries end of....
#63 dan meads
dan meads
    Newbie
  • Pip
  • 6 posts
  • Name: daniel
  • Ford Model: 2.0 tdci
  • Year: 2006
Posted 28 August 2014 - 09:06 PM
The dpf is £172 I think it's just clogged it's not in limp mode constantly I can turn the car off then back on and it's fine until I speed down the road then it wil do it again how much is a remap roughly Andy?
#64 dan meads
dan meads
    Newbie
  • Pip
  • 6 posts
  • Name: daniel
  • Year: 2006
Posted 28 August 2014 - 09:09 PM
I'm just stuck as to what to do I want to do it the cheapest way but also want the car to run ok I was thinking of just getting rid of it for cheap and buy a new car cos I was told the car ain't worth the cost of repair
#65 dan meads
dan meads
    Newbie
  • Pip
  • 6 posts
  • Name: daniel
  • Year: 2006
Posted 28 August 2014 - 09:12 PM
Stoney where is the fluid topup bottle?
#66 Andy.B1971
Andy.B1971
  • 340 posts
  • Name: Andy
Posted 28 August 2014 - 09:13 PM
I have not got the foggiest Daniel lol :iim: I am sure someone will pop along and tell you I am sure its about £450 gutted and remapped, a fair amount BUT if you plan on keeping the car then an investment really....
goodbye car hello newer car
#67 dan meads
dan meads
    Newbie
  • Pip
  • 6 posts
  • Name: daniel
  • Year: 2006
Posted 28 August 2014 - 09:24 PM
Il get some quotes tomorrow thanks for your Andy
#68 dan meads
dan meads
    Newbie
  • Pip
  • 6 posts
  • Name: daniel
  • Year: 2006
Posted 28 August 2014 - 09:27 PM
Help*
#69 Marks12
Marks12
    Serial Poster
  • 459 posts
  • Name: Mark
  • Ford Model: Focus Zetec 1.8 TDCI
Posted 06 September 2014 - 07:43 PM
Hi I am new here and I have a problem with my 08 ford focus mk2 1.8 TDCI zetec ok 2 problems.
Problem number 1 which was the first one i noticed is when I am driving at any speed particularly at 100 kilometers an hour and i gradually take my foot off the gas for a few seconds and it will slow down but when its going from 100 down to 80  the car will chug like its about to cut out  (best word i can think of to describe the issue). This is when I am in 5th gear I have also noticed it happening in 4th gear as well. (and no I'm not just changing down gears).
Problem number 2, This problem only occurred today on the way in to work as I put the window down the ABS and the warning light came on some other light also came on, as i put the window up the same lights came on and the radio shut off as if the car was turned off and i had locked it. (which obviously isnt the case when i was going 80kilometers and hour at the time)
and ideas would be greatly appreciated
#70 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,345 posts
  • Name: James
  • Year: 2007
Posted 06 September 2014 - 07:57 PM
Ideally you need to start your own thread I can't do this for you on a mobile. Go to the Ford focus section and click new topic / thread in the top right
#71 Marks12
Marks12
    Serial Poster
  • 459 posts
  • Name: Mark
Posted 06 September 2014 - 08:03 PM
thanks will do
#72 Son of Nod
Son of Nod
  • 32 posts
  • Name: Anthony
  • Year: 2006
Posted 17 September 2014 - 09:04 AM
Happened to me:
The heated windscreen can fail on one side either its a simple fuse issue to which there are 2 1 for each side or some cars under the scuttle panel have the electrical ribbon loose which gets rubbed by the wipers when in motion causing it to fail.
Power steering hose just behind the radiator and at the join to the pump are prone to leaks from corrosion recommend every 6 months applying grease to the area such as vaseline to prevent this.
#73 theredfox
theredfox
  • 329 posts
  • Name: paul
  • Ford Model: c- max
  • Year: 2005
Posted 10 October 2014 - 12:13 AM
hi all
take it these problems are common to c-max models as well
tia
paul
#74 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,345 posts
  • Name: James
  • Year: 2007
Posted 10 October 2014 - 12:47 AM
The 1.6tdxi up until 2006 has a poor designed intercooler pipe that cracks easily, and the auto gearbox (zf) has a known failure issue. Beyond that they tend to share the characteristics of the focus
#75 theredfox
theredfox
  • 329 posts
  • Name: paul
  • Year: 2005
Posted 10 October 2014 - 05:08 PM
thanks for that info james
Not what you're looking for?
Also tagged with one or more of these keywords: focus, ford, mk2, common problems
