Ford Oc App Ios Now Out (Based On Tapatalk) Update!! Now Out On Ios And Android
ford oc app app Tapatalk android
67 replies to this topic
#61 higgsy
higgsy
    Northern Yam Yam
  • Budding Enthusiast
  • 835 posts
  • Name: James
  • Ford Model: Focus Zetec S 1.6 TI-VCT
Posted 14 August 2014 - 10:41 AM
For some time now, I am getting constant crashes from the android app. This isn't too bad when you are just generally browsing, however when it happens when you are in the middle of writing a fairly long reply its irritating.  I have taken a bit of time to investigate and have found its always the same errors causing the crash. I run a custom AOSP rom, however I have also been able to recreate the problem on the stock Google ROM.
Issue seems to be related to google analytics implementation and is always the same error causing the crash. See below extract from logcat:
08-14 10:11:00.252 E/AndroidRuntime(30461): FATAL EXCEPTION: disconnect check
08-14 10:11:00.252 E/AndroidRuntime(30461): Process: com.tapatalk.fordownersclubcomforums, PID: 30461
08-14 10:11:00.252 E/AndroidRuntime(30461): java.lang.IllegalArgumentException: Service not registered: com.google.analytics.tracking.android.AnalyticsGmsCoreClient$AnalyticsServiceConnection@427be620
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:922)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at android.app.ContextImpl.unbindService(ContextImpl.java:1611)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at com.google.analytics.tracking.android.AnalyticsGmsCoreClient.disconnect(AnalyticsGmsCoreClient.java:95)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at com.google.analytics.tracking.android.GAServiceProxy.disconnectFromService(GAServiceProxy.java:293)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at com.google.analytics.tracking.android.GAServiceProxy.access$1100(GAServiceProxy.java:27)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at com.google.analytics.tracking.android.GAServiceProxy$DisconnectCheckTask.run(GAServiceProxy.java:367)
08-14 10:11:00.252 E/AndroidRuntime(30461): 	at java.util.Timer$TimerImpl.run(Timer.java:284)
08-14 10:11:00.252 W/ActivityManager(854):   Force finishing activity com.tapatalk.fordownersclubcomforums/com.quoord.tapatalkpro.ics.slidingMenu.SlidingMenuActivity
My Build info -
build.board: hammerhead
build.bootloader: HHZ11k
build.brand: Google
build.cpu_abi: armeabi-v7a
build.cpu_abi2: armeabi
build.device: hammerhead
build.display: KTU84Q test-keys
build.fingerprint: google/hammerhead/hammerhead:4.4.4/KTU84P/1227136:user/release-keys
build.hardware: hammerhead
build.host: dariosf-purity
build.id: KTU84Q
build.manufacturer: LGE
build.model: Nexus 5
build.product: hammerhead
build.radio: unknown
build.serial: 03a87a2f08eaac8d
build.tags: test-keys
build.time: 1407429482000
build.type: user
build.user: dariosf
version.codename: REL
version.incremental: eng.dariosf.20140807.183654
version.release: 4.4.4
version.sdk_int: 19
I'm not sure who develops your app, however I would appreciate it if you could forward this info onto them for investigation.  I have been sending error reports, however the problem has persisted, which has prompted my post here.
Ta!
Higgsy
Have something to contribute?
#62 jamesm182
jamesm182
    Management
  • Admin
  • 1,477 posts
  • Name: James
Posted 14 August 2014 - 03:20 PM
Hi Higgsy,
Unfortunately the Ford OC app is basically just a skin over tapatalk so we don't actually have access to the development of it other than a few basics. Fingers crossed a future update will solve your problems but I will be sure to pass on your findings anyway.
Cheers
James
#63 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 14 August 2014 - 03:45 PM
I have no issues with tapatalk, and to be fair never have, i use it constantly to access 8 other forums I use, unfortunately FOC won't allow access via taptalk directly.
FOC app was last updated 09/05, where as tapatalk was last updated yesterday and probably 5 times since May.
FOC app def needs to be updated with the latest sources from tapatalk, however Im not convinced tapatalk in general is at fault, I believe it is google analytics implementation which can be optionally included when you build your own app based on tapatalk. Then again if the code for this is off the shelf then it may well have been fixed in the last 3 months.
Cheers for replying anyway though.
#64 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 14 August 2014 - 05:43 PM
Just got an update! Hopefully will address the crashes!
#65 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 14 August 2014 - 07:58 PM
Woo hoo been using for the last hour or so and no crashes! Also the app is now remembering the last position you were is when it was last closed ie always opening on Timeline.
#66 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,118 posts
  • Name: Clive
  • Year: 2015
Posted 14 August 2014 - 08:00 PM
Ditto.
Looking good so far.
#67 SeanW
SeanW
  • 1,490 posts
  • Name: Sean
  • Ford Model: Focus
  • Year: 2009
Posted 14 August 2014 - 10:49 PM
Just updated it on my tablet, and it's still crashing/refusing to load threads :-(
I also use the Fiat Forum app (basically the same as the FOC app) and the Tapatalk app with virtually no problems
#68 jamesm182
jamesm182
    Management
  • Admin
  • 1,477 posts
  • Name: James
Posted 15 August 2014 - 07:48 AM
So the update has solved at least some of your problems  :)
Will try and see if we can get the updates rolling out a little more regularly.
Not what you're looking for?
Also tagged with one or more of these keywords: ford oc app, app, Tapatalk, android
