AdBlock Warning
Harrowman
Ford Focus Or C-Max 1.8 Tdci Engine Wiring Loom
Hi, I need an engine wiring looms for my C max diesel 2008 manual, so far I could not find a used one and the ford quoted me a fortune for that. in fact I have lost one of the plugs which goes to ECU in an accident so I have to change the whole looms. the code is 8M5T-14K733 VBA.
Any suggestion please,
john
It will be a 1.5.
Mk1- 2003 - 2007
Mk1.5 - 2007 - 2011
Mk2 - 2011 -
For a loom from Ford you'd be looking at £500 +
Unfortunately nothing matching on ebay at the moment.
May be worth calling a couple of breakers to see if there's anything suitable.
It seems rather dramatic to seek a new loom when all you say you have damaged is the plug.
Surely its possible to find a breakers with a smashed car, cut the section of loom that goes to the ecu, then splice the new plug and cable onto your old loom with connectors.Its not as if this is a new car.
I will go look at my 1.8tdci Focus in the morning.
Incidentally, do you find your EGR gives a shushing noise at certain throttle openings? Mine always has.
Have a root on ebay.
There's usually a few looms available.
You can uae a Focus loom too as they're the same.
thanks for your reply, I have already bought a couple of the looms one from Ford Galaxy and another from Mondo but both have more wiring then mine although the same plug.
is it a MK1 or MK1.5 CMAX? I cant remember immediately when the MK2 came out.
I would not know much about it, as I am looking at the log book I can see Category M1 Variant KKDA1E Version 5KAB N3
It will be a 1.5.
Mk1- 2003 - 2007
Mk1.5 - 2007 - 2011
Mk2 - 2011 -
I did called many unfortunately no luck so far.
according stoney it is MK1.5
is it a MK1 or MK1.5 CMAX? I cant remember immediately when the MK2 came out...
I got a couple of looms already but the they are more wires in them than mine, looked for the diagram could find it yet
