Fitting Hids
lighting
23 replies to this topic
#16 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
  • Ford Model: Focus Zetec S
Posted 26 October 2013 - 09:26 PM
I'm currently carrying out a mod for retrofitting legal HID including washers n self leveling to my mk2.5 focus if your interested check my build thread for progress. Thus far I've calculated an estimated cost. Roughly around £700/£800 if you have the HID loom already installed in your car if you don't the cost will require another £400 for the wiring. There is no really not much of a cheaper option retrofitting legal HID. £40 for an ebay kit that has the potential for a fine plus points
Have something to contribute?
#17 welshy_maverick
welshy_maverick
  • Budding Enthusiast
  • 278 posts
  • Name: Welshy
  • Ford Model: Fiesta ST-2 Frozen White
  • Year: 2013
Posted 28 October 2013 - 01:00 AM
unless your going to install headlamp washers, self levelling and have them all working, you will fail an MOT, and be presented with a rectification notice from the police at best, if not, you could be fined for driving a vehicle other than in a roadworthy condition.
well that simply isnt true. you can retro fit HID's as long as the output and beam pattern are set correctly they will pass and MOT as plenty of people I know have done. As for washers and self levellers...if your car came out of the factory with them or you have retro fitted them they must work, however they are not required to be fitted,
Hate to post a link to the dark side but this post on the corsa forum may be useful...
http://www.corsa-c.c...HIDS-April-2012
http://www.astraowne...its-MOT-The-Law
I have them, rang up my insurance ( last month : sept 13) and declared them no problem and no insurance premium increase!!
hope that helps!!
#18 Mike77
Mike77
  • 959 posts
  • Name: Mike
  • Ford Model: Fiesta 1.6 TDCI Titanium
Posted 28 October 2013 - 02:04 AM
Makes for an interesting read,,,, 'GOOD FIND'  :ph34r:
#19 Dave-2912
Dave-2912
  • 195 posts
  • Name: Dave
  • Ford Model: Mk7.5 Fiesta ZS
  • Year: 2013
Posted 28 October 2013 - 08:11 AM
How many HID threads does one forum need??? It's second only to 'Which bulbs do I need for <insert location>.
The OP didn't even ask about the legality (which always end up being the talking point).
Welshy, some of what you say is true but levellers and washers are still required to be fitted aftermarket (along with a new headlight housing). Its just that the MOT doesn't check for them...
I agree that MOT stations WILL generally pass a car with HIDs. I haven't tried it but their test requirements in this area are so wooly that they would have no choice to pass what is an illegal mod.
The MOT information which relates to this:
http://www.motuk.co.uk/manual_170.htm
The important bit is "Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system." The wording "MAY be fitted" insinuates that these items do not need to be in place so I can understand why HID conversions get through an MOT.
The MOT guidelines are not the bible of roadworthyness though. The Department for Transport clearly state that fitting HID lamps aftermarket is illegal without also:
- Changing the headlight enclosure for one designed for HIDs.
- Fitting self levelling to the headlights or suspension.
- Fitting headlight washers.
See Link:
http://webarchive.na...d-headlamps.pdf
The headlamp housing must be changed because of the way that the light is produced by HID lamps. Have a look at this website:
http://www.danielste...onversions.html
It explains why retrofit HIDs should not be judged soley on the beam pattern cut-off. (I suspect this is what the MOT test looks for?)
The MOT test is therefore not doing it's job in keeping vehicles roadworthy but it's something we all have to live with until the government gets its act together. The police are not guided soley by the MOT rules so if you come across a clued-up copper, you might still have a problem.
Insurance companies agreeing to insure HID conversions only serves to muddy the waters even further. So an MOT pass does not mean HID lights are legal to use but you will probably get away with it.
#20 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 28 October 2013 - 07:38 PM
hope that helps!!
I would not bother arguing this point Welshy. It's already set in stone and def on a gov.uk site i've seen it before just can't find it.
Many people are confused about two things with HID of what part is legal. The sale of HID is legal the fitting of HID is also legal HOWEVER it is now required that aftermarket HID MUST meet the same requirements as factory fitted HID. No factory car with HID comes without washers or self leveling.
The requirements of factory fitted HID is that:
They must be used with projector type lens
They must have a self cleaning system, wipers with washers or jet powered washers
They must have self leveling either done by the headlight unit using sensors or with self leveling suspension usually on the rear.
The light emitted must be white or yellow this goes for halogen too. (Although HID may have a slight blue look as far as light emitted colour goes it's still white)
Second part that confuses some people is projector type lens, although this is the type of lens use for HID it can also be used for halogen bulbs too (If designed for it, HID bulb holders are different from halogen)
You can also fit them with xenon looking halogen bulbs, these are normal halogen bulb filled with a a type of gas to give a "xenon" look, these are still just ordinary halogen bulbs and don't require any washers or self leveling.
On the subject of MOT's and so on many garages will pass it and many will also fail it, not everyone is upto date on the changes not every tester is fussy.
Your insurance company isn't going to hassle you for declaring what is a legal mod, if you have an accident though your insurance company may put your car through test to see if it was road worthy as it's the responsibility of the driver to ensure the vehicle is road worthy, not the insurance company nor is it the MOT tester's responsibility.
#21 Dave-2912
Dave-2912
  • 195 posts
  • Name: Dave
  • Year: 2013
Posted 28 October 2013 - 08:14 PM
Look no further:
https://www.gov.uk/g...ormation-sheets
Link 2 of the download information sheets section is the one you're after.
Its what I already linked to in my previous post. :)
#22 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 28 October 2013 - 08:32 PM
Look no further:
Nice one bro, it's always good seeing it directly from gov.uk rather than another car club site. saved it to my favourites this time :D
Just to add to my previous reply, points are given for this offence btw hence the reason why i am retrofitting HID the correct way with washers and self leveling
#23 Dave-2912
Dave-2912
  • 195 posts
  • Name: Dave
  • Year: 2013
Posted 28 October 2013 - 08:43 PM
No bother.
I had a quick look at your build thread after your earlier post. Nice to see someone doing the HID thing properly!
#24 b1g_dav3
b1g_dav3
  • 2,563 posts
  • Name: David
  • Year: 2013
Posted 29 October 2013 - 11:34 AM
HID kits aren't e marked, which I believe they must be in order to be legal or something >_>
I have them though and have had no problems.
Not what you're looking for?
Also tagged with one or more of these keywords: lighting
