Daz P
Radio Problem
3 posts in this topic
I got in the car this morning to go to work as normal radio working fine but then i actually looked at the radio and there was no display no light no power but the radio was working?
I can operate it from the steering wheel but i have no function on the radio. The power on/off works but thats it.
Its a Zetec on an 11 plate only a recent purchase the radio is a 6000.
Do you think it could be a water ingress problem due to the bad rain we have been getting?
Any help would be much appreciated.
Daz
It could be a loose ribbon connector inside the radio between the faceplate and the tuner board..
More than likely the radio has crashed. The Visteon & sony units are very prone to this.
Pull the fuse and re-insert it - will reset the radio.
Just make sure you have the security code first!
