New Head Unit With Rear View Camera Problems
9 replies to this topic
#1 k13r4n
k13r4n
  • True Ford Enthusiast
  • 747 posts
  • Name: kieran
  • Ford Model: MK7 Fiesta Metal
  • Year: 2011
Posted 25 October 2013 - 05:47 PM
Ok guys i bought myself a funky new head unit that's a direct fit like some of you have done on your focuses. I also received a rear view camera which is the problem.http://m.youtube.com...th the av feed
Have something to contribute?
#2 k13r4n
k13r4n
  • 747 posts
  • Name: kieran
  • Year: 2011
Posted 30 October 2013 - 10:12 PM
anybody ?
#3 higgsy
higgsy
    Northern Yam Yam
  • Budding Enthusiast
  • 835 posts
  • Name: James
  • Ford Model: Focus Zetec S 1.6 TI-VCT
Posted 30 October 2013 - 10:46 PM
You might get a better response if you actually state what the problem is :blink:
#4 k13r4n
k13r4n
  • 747 posts
  • Name: kieran
  • Year: 2011
Posted 30 October 2013 - 10:52 PM
When car ignition is on the rear view camera is perfect. But when the rear view camera is activated when engine is running there is lines and sometimes not even a display from the camera as per the video above
#5 Turvey
Turvey
  • 561 posts
  • Name: Kevin
  • Ford Model: Focus 1.6 Zetec
  • Year: 2005
Posted 30 October 2013 - 11:01 PM
Someone comments under the video that you have to install a relay "onto the voltage wire and colelct the 12V from fuse or somewhere the voltage is stronger with power"
​Not being electrically minded it means nothing to me though  :wacko:  :)
#6 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 31 October 2013 - 12:40 AM
It is possible the engine (eg - the ignition/ ht leads or alternator etc) is interfering with the signal (either air-bourn or through the cables/power supply)
On the original Golf HTI 16v, the radio ariel was relocated to the back of the roof because the engine interfered with the radio in the normal position- thus starting the trend for rear mounted arials (it was not intended as a styling or aerodynamic thing)
If you took the (power) feed for the head unit and camera derectly from the battery, that will help with power/ cable bourne interference (you may need an extra/ additional power switch for the audio) as the battery acts as filter/ damper to power-bourn interference - you can also add filters/ suppressors
Careful shielding would help with the air-bourne (radio/ rfi) interference, (eg co-axially shielded cable for the video feed) and adding ferrite cores/ chokes to the signal wires
re-routing the earths can help too ,
there is also a possibility that the voltage changes/ raises when the engine is running (eg upto 16v) due to the smart-charge system - and the camera cannot handle this voltage - a voltage regulator could help
Alternatively you could try a different camera (it may cope with the conditions(voltage/ interference) better)
#7 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 31 October 2013 - 07:59 AM
Excellent post there FOCA.I was going to say interference from the engine for sure
#8 btmaldon
btmaldon
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
  • Ford Model: BMW 320i Coupe M Sport, KA Luxury
Posted 31 October 2013 - 09:54 AM
The power to the camera should be attached to the power to one of the reversing light bulbs and a separate earth. The canbus switches the screen to camera automatically when you select reverse I pressume.
#9 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 31 October 2013 - 04:39 PM
Thanks - yes, there must be a reason it works with the engine off - interference from the engine is the most likely culprit
It might be useful to have the camera working even when reverse is not selected, i am fitting a system with front/ rear cameras with manual/auto record/ playback feature o-lux IR (total darkness)  and a 24/7 security recorder with motion detector to protect the car when driving and also when it is parked   (a bit like a home security system but for the car)
#10 btmaldon
btmaldon
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
Posted 31 October 2013 - 05:15 PM
It looks like from the video that the camera is switching off when you turn the ignition on but the unit is still trying to show a picture. It is wired for the camera to only switch on when you select reverse gear?
Not what you're looking for?
