Aldoo Posted October 27, 2013 Share Posted October 27, 2013 Hifor as long as I remember my 1.8 tdci has taken ages for the temperature dial to go up to working temp(just below half on the dial on mine)as id never drove a car similar to it I didn't know if it was normal so did nothingbut I've just noticed that the blowers are actually blowing warm air within about 2mile(5 mins-ish) but it still reads that its not even started warming. I can sometimes go to work 12 miles away and the dial has barely even moved!!is this normal?? cheers! Quote Link to comment Share on other sites More sharing options...
shamus1 Posted October 27, 2013 Share Posted October 27, 2013 Hi for as long as I remember my 1.8 tdci has taken ages for the temperature dial to go up to working temp(just below half on the dial on mine) as id never drove a car similar to it I didn't know if it was normal so did nothing but I've just noticed that the blowers are actually blowing warm air within about 2mile(5 mins-ish) but it still reads that its not even started warming. I can sometimes go to work 12 miles away and the dial has barely even moved!! is this normal?? cheers! my 2.0 tdci is exactly the same driven sensibly but if I boot it it will warm up quicker. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted October 27, 2013 Share Posted October 27, 2013 I'm pretty sure its not normal. All my Petrol Focus's have reached normal temperature within 1 mile. May be a little different with a diesel but I wouldn't have thought that much. You may just have a lazy thermostat. Its not a major issue but you may loose out on some fuel efficiency. Quote Link to comment Share on other sites More sharing options...
jamesm182 Posted October 27, 2013 Share Posted October 27, 2013 I think it's a diesel thing isn't it? 1 Quote Link to comment Share on other sites More sharing options...
higgsy Posted October 27, 2013 Share Posted October 27, 2013 Diesel thing for sure. My 1.6 focus is at full temp by the end of my street pretty much. My old 1.3 cdti corsa never got warm in the winter the needle never moved in my 5 mile journey to work. One of the reasons diesels are more economical as with petrols a lot of the energy is lost/wasted with the heat which is a by product of the combustion process. Sent from my Nexus 4 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Captain Haddock Posted October 27, 2013 Share Posted October 27, 2013 Go to Ford Etis, click on the 'Vehicle' tab, bung your registration number in the left hand box and click 'Search'. Assuming you get a 'Vehicle Summary' page back then click on the 'There are more minor features for this vehicle, click to expand this list' link under 'Minor Features' to expand the list. Look down the list and see if you have 'With Supplemental Air Heater' displayed then your car's heater has an electric ceramic heating element that's used to heat the cabin air if the engine hasn't reached normal operating temperature and outside air temperature is less than +10C. At least I think it's 10C as mine seems to come on around that point and it sure makes the now colder pre-dawn mornings at lot more tolerable. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 27, 2013 Share Posted October 27, 2013 diesels run cooler far cooler than petrols and take a lot longer to heat up in cold weather thats why trucks have covers to block the radiator and increse the engine temp quickly the dial on the dash shows coolant temperature not the engine temperature so until the coolant has gone through the engine bypassing the rad and back to the expansion bottle and so on when it gets warm you get a reading using the fans takes heat from the engine so in cold weather the coolant may never go through the rad 1 Quote Link to comment Share on other sites More sharing options...
btmaldon Posted October 27, 2013 Share Posted October 27, 2013 Just goes to show how little I know about diesels. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 28, 2013 Share Posted October 28, 2013 Ita the same process for petrol and diesel but as any petrol owner knows when its 5 degrees it takes a bit longer to get up to temp diesels just run cooler so they on short trips may never really warm up thats why taxis sit with the engine running all the time Quote Link to comment Share on other sites More sharing options...
mjt Posted October 28, 2013 Share Posted October 28, 2013 I think there's an additional reason. To cope with the higher compression there's more metal in the block and particularly the head which is why a diesel lump is heavier than a petrol. Therefore there's a greater volume of metal to heat up and a bit more thermal resistance between combustion chamber and coolant. Quote Link to comment Share on other sites More sharing options...
Aldoo Posted October 28, 2013 Author Share Posted October 28, 2013 That's great guys, thanks :) I thought it must be normal as it still drives lovely I might cover the radiator for winter now. I know my mate did on his merc van last year, said it warmed up quicker but its running temperature was no higher Cheers Quote Link to comment Share on other sites More sharing options...
shamus1 Posted October 28, 2013 Share Posted October 28, 2013 I did drive a Peugeot 308 1.6 hdi before my focus and bought a genuine Peugeot cover that clicked in the bottom bumper grille for the winter,worked a treat for warming car up quicker,dont think ford did one. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 28, 2013 Share Posted October 28, 2013 On the mk2 on tge lower grills it does look like theres tabs for some sort of plastic cover to fit on Quote Link to comment Share on other sites More sharing options...
FOCA Posted October 28, 2013 Share Posted October 28, 2013 That's great guys, thanks :) I thought it must be normal as it still drives lovely I might cover the radiator for winter now. I know my mate did on his merc van last year, said it warmed up quicker but its running temperature was no higher Cheers When you start your engine the mechanical pump starts running, the coolant (water) goes into the block at the pump and out at the head, where it can go 2 ways - before the thermostat opens it does not go through the radiator and goes to the heater, on the mondeo there is an electric heater to heat the water before it gets to the heater (this is to warm the water quicker and so you get heat from the heater quicker) the water then gets returned to the pump, where it goes round again This continues (the water circulates through the block, heater then back to the pump, and does not go through the radiator) untill the engine warms up when the operating temp is reached - the thermostat opens - this diverts the water through the radiator which makes the temprature drop - which closes the thermostat - so the water is circulated and the thermostat opens and closes to maintain the temprature now, if it is a really cold day and you are taking a lot of heat out of the system the thermostat may not open (and the water circulate through the radiator) at all - if the temp does not reach the thermostat opening temp - so in this case covering the radiator would make hardly any difference at all (depends on the engine/ conditions) - apart from effectively disabling the system when the thermostat opens with potential for the system to overheat - half - covering the radiator may be safer than completely covering it As others have said, these diesels do take quite a bit of warming up but keeping the heater off for a bit longer and running the fan at a lower speed/ running the heater at a lower temp can help a lot, (or you are liable to take all the heat out of the system) and running the engine a bit harder (within reason, of course) the temp gauge on the dash is connected to the temp sender on the head (the metal on the head, not the water)- the ECU also uses this for the engine temp - it (normally) starts at 40 degrees C - the water may heat up a bit/ you may get a little heat out of the heater before the gauge moves Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 29, 2013 Share Posted October 29, 2013 the temp gauge on the dash is connected to the temp sender on thehead (the metal on the head, not the water)- the ECU also uses this forthe engine temp - it (normally) starts at 40 degrees C - the water mayheat up a bit/ you may get a little heat out of the heater before thegauge moves not entirely true it depend wether you have a cht sensor coolant sensor or both some fords have both some only have the cht i belive the 1.8 diesel has the cht only as far as ford are concerned all petrols have both a cht sensor and a coolant sensor either way both do the same job the issue is its just a rough gauge if you do the dash test you will get the cht temp say 120 for example but the gauge will show 80 degrees there s a 40 degree variance between the head temp and coolant but the gauge on the dash shows the coolant temp not the engine temperature thats in the dash test menu thats why the engine can be warm but the gauge not show that as its the coolants temperature that increases the gauge A basic description of the sensor is that it is a thermistor devicein which resistance changes with temperature. As the temperatureincreases the resistance decreases causing a voltage drop to occur onthe 5 volts signal wire. The PCM receives the various voltage signalsand equates it to a temperature value. All sounds like a pretty standardsensor. That is until you actually use Ford’s material to diagnosesensor fault issues. There you will find the following description: “On applications that do not use an engine coolant temperature (ECT)sensor, the CHT sensor is used to determine the engine coolanttemperature. To cover the entire temperature range of both the CHT andECT sensors, the PCM has a dual switching resistor circuit on the CHTinput (5 volt line). A graph (Figure 3) showing temperature switchingfrom the “COLD END” to the “HOT END” line, with increasing temperatureand back with decreasing temperature is included. Note the temperatureto voltage “OVERLAP ZONE.” Within this zone it is possible to haveeither a “COLD END” or HOT END” voltage at the same temperature. Forexample, at 90°C (194°F) the voltage could read either 0.060 volt or3.71 volts (Figure 4).” also from the repair manual The temperature gauge measures the temperature of your car’s enginecoolant. It is important to take note of this gauge because it will tellyou if your engine is overheating this happens when the temperature of the coolant gets too high and cannot effectively cool the engine anymore so the red zone basically means the coolant has got to the point where it is boiling. Typically, the gauge should read “cold” when you start the car and get warmer as you drive. . Quote Link to comment Share on other sites More sharing options...
chris_h Posted October 29, 2013 Share Posted October 29, 2013 Mine is exactly the same, the temp needle takes a few miles to jump, but when I rag its balls off...wooosh needle jumps up Quote Link to comment Share on other sites More sharing options...
