aliturk Posted November 2, 2013 Share Posted November 2, 2013 Had a bit of a panic not long ago. Went down to move the car, put key in ignition but it wouldn't turn. Didn't seem broken, more like something was deliberately preventing it from turning. After pausing to think, I tried again, this time rocking the steering wheel slightly, I could feel a catch release and was able to turn the key and the wheel unlocked. It does seem a bit of a dark art and I'm wondering if something needs adjusting. I actually don't normally engage the steering lock, i must have done it unknowingly. The manual just says to unlock the steering, depress the clutch or turn the key. Quote Link to comment Share on other sites More sharing options...
potter18 Posted November 2, 2013 Share Posted November 2, 2013 If the steering lock is engaged you usually have to move the steering wheel slightly to turn the ignition key don't think that it's a problem but keep your eye on it Quote Link to comment Share on other sites More sharing options...
L666JER Posted November 2, 2013 Share Posted November 2, 2013 I had exactly the same problem earlier on in the year, steering lock difficult to get off, eventually it would not come off at all. Had to get the breakdown man out - he took the lock barrel out and just started it with a screwdriver. Ended up just replacing all the locks. Apparently the locks are made of cheap metal so they wear out quickly - mine had only done 30,000 miles. I got a brand new full lock set off eBay for about £40, took me a couple of hours to fit, and about £20 to have 2 new keys cut so I could put the imobiliser chips in. By the way is it a Mk2 or 3 fiesta, its just the Mk3 came out in 1989? EDIT - just seen your profile picture, you need to update profile information as it says 1989 fiesta. Sorry :) Quote Link to comment Share on other sites More sharing options...
aliturk Posted November 2, 2013 Author Share Posted November 2, 2013 If the steering lock is engaged you usually have to move the steering wheel slightly to turn the ignition key don't think that it's a problem but keep your eye on it Yes I'll keep an eye. It wouldn't bother me but the manual says to disengage steering lock, depress the clutch or turn the key. Maybe the steering lock unlocks electronically normally, but the method I'm using is a sort of emergency manual unlock. I'll email the dealer. I never normally engage the steering lock - waste of time in this day and age I think. By the way just updated my profile, it's a brand new fiesta I'm having this issue with. Quote Link to comment Share on other sites More sharing options...
Willy Posted November 3, 2013 Share Posted November 3, 2013 It's all normal guys. The steering wheel has an automatic electronic lock which locks when you lock the car. If you leave the steering wheel turned when you lock it you'll find it hard to unlock later. As said before you will need to wiggle the wheel to release the lock. No need for a trip to the dealer. Best way to avoid this happening is to leave your wheels strait when you've parked :p Quote Link to comment Share on other sites More sharing options...
aliturk Posted November 3, 2013 Author Share Posted November 3, 2013 It's all normal guys. The steering wheel has an automatic electronic lock which locks when you lock the car. If you leave the steering wheel turned when you lock it you'll find it hard to unlock later. As said before you will need to wiggle the wheel to release the lock. No need for a trip to the dealer. Best way to avoid this happening is to leave your wheels strait when you've parked :P That's what a mate of mine metioned, and the wheels were hard locked to the left. I shall keep the wheels straight next time i park :-) Quote Link to comment Share on other sites More sharing options...
LeroyE Posted November 3, 2013 Share Posted November 3, 2013 wow it's the first time i'm seeing another hot mustard/mustard olive :PSorry for going off topic :P Quote Link to comment Share on other sites More sharing options...
aliturk Posted November 3, 2013 Author Share Posted November 3, 2013 wow it's the first time i'm seeing another hot mustard/mustard olive :P Sorry for going off topic :P It's certainly easy to locate at busy car parks :-) Quote Link to comment Share on other sites More sharing options...
LeroyE Posted November 4, 2013 Share Posted November 4, 2013 It's certainly easy to locate at busy car parks :-) hahahha. I can imagine this situation: Dude, where's my car??!! I don't know, but mines right over there :P Quote Link to comment Share on other sites More sharing options...
