Egr Blanking Ford Focus
Egr blanking ford focus
67 replies to this topic
#61 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 16 November 2013 - 10:42 PM
EGR in spark-ignited enginesIn diesel enginesEdit
In modern diesel engines, the EGR gas is cooled with a heat exchanger to allow the introduction of a greater mass of recirculated gas. Unlike SI engines, diesels are not limited by the need for a contiguous flamefront; furthermore, since diesels always operate with excess air, they benefit from EGR rates as high as 50% (at idle, when there is otherwise a large excess of air) in controlling NOx emissions.[citation needed] Exhaust recirculated back into the cylinder can increase engine wear as carbon particulate wash past the rings and into the oil.[6]
Since diesel engines are unthrottled, EGR does not lower throttling losses in the way that it does for SI engines. Exhaust gaslargely carbon dioxide and water vaporhas a higher specific heat than air, so it still serves to lower peak combustion temperatures. However, adding EGR to a diesel reduces the specific heat ratio of the combustion gases in the power stroke. This reduces the amount of power that can be extracted by the piston. EGR also tends to reduce the amount of fuel burned in the power stroke. This is evident by the increase in particulate emissions that corresponds to an increase in EGR.[7]
[8] Particulate matter (mainly carbon) that is not burned in the power stroke is wasted energy. Stricter regulations on particulate matter(PM) call for further emission controls to be introduced to compensate for the PM emissions introduced by EGR. The most common is a diesel particulate filterin the exhaust system which cleans the exhaust but reduces fuel efficiency. Since EGR increases the amount of PM that must be dealt with and reduces the exhaust gas temperatures and available oxygen these filters need to function properly to burn off soot, automakers have inject fuel and air directly into the exhaust system to keep these filters from plugging up.
By feeding the lower oxygen exhaust gas into the intake, diesel EGR systems lower combustion temperature, reducing emissions of NOx. This makes combustion less efficient, compromising economy and power. The normally "dry" intake system of a diesel engine is now subject to fouling from soot, unburned fuel and oil in the EGR bleed, which has little effect on airflow, however, when combined with oil vapor from a PCV system, can cause buildup of sticky tar in the intake manifold and valves. It can also cause problems with components such as swirl flaps, where fitted. Diesel EGR also increases soot production, though this was masked in the US by the simultaneous introduction of diesel particulate filters.[9] EGR systems can also add abrasive contaminants and increase engine oil acidity, which in turn can reduce engine longevity.[10]
Sent from my SM-N9005 using Ford OC mobile app
Looks like that was copied word-for-word out of wikipedia - wikipedia is just filled with peoples ideas, opinions,(like mine) not nessesarily facts
On a diesel engine, the EGR valve/ system allows burnt carbon/ soot back into the inlet, to contaminate and eventually choke up the inlet manifold etc over time, choking the engine, reducing the efficiency/ performance/ MPG(and increasing the smoke output) this is the trouble with fitting an EGR to a diesel (aka compression ignition/ not SI/ spark ignition, or petrol engined to you and me) engine in practice, whatever the theoretical benifits are
Have something to contribute?
#62 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 16 November 2013 - 10:51 PM
I am going to install it as there are just too many people on here with the same engine as me who have suffered no ill effects whatsover. Only gains from doing it.
I was going to have my DPF deleted by a friend of the person who I bought the car off for just £350 but, after speaking to him today, it seems this guy is a mobile deleter and I dont think I want such an important item to be done by a mobile outfit??
He told me they are very thorough and remap the engine and also delete the egr at the same time.
Mobile fitters?? Any good??
There would be some debate about this -
there are good and bad garages and good and bad mobile mechanics / fitters (just because they are mobile does not nessesarily make them "bad") - a top firm would have premises, a rolling road, an established reputation etc though
#63 Blurredfocus
Blurredfocus
  • Budding Enthusiast
  • 39 posts
  • Name: Ryan
  • Ford Model: Focus zetec s 1.6tdci
Posted 17 November 2013 - 08:08 AM
That's exactly what mark lord was saying if you read it right ! The only benefit in his entire post mentioned about a diesel EGR is it stables idling because it reduces over feeding of air (at idling) I myself thought what he put was pretty spot on. You must've have too because you've more or less repeated the latter comments of his post .
#64 exponential
exponential
  • 410 posts
  • Name: Michael
  • Ford Model: 1.6 TDCI Focus Estate Titanium (109)
  • Year: 2009
Posted 17 November 2013 - 09:12 AM
I think I would much prefer for my car to go on a rolling road in a controlled environment both before and after removal/remap to ensure stability.
Don't get me wrong, im sure that most mobile fitters are very professional and efficient but I cant allow somebody to come to my car, plug in some hardware into my ecu, delete a load of important info, remap then say "youre done, on your way" without any thorough testing.....
Probably being over cautious maybe??
#65 marklord1983
marklord1983
  • 68 posts
  • Name: Mark
  • Ford Model: focus
  • Year: 2007
Posted 17 November 2013 - 09:13 AM
I got that post off wiki but it was from a official agency in the EU it wasn't just someone who put his own opinions on there, a friend of mine is a mechanic and he's said blank it off as the dpf won't clog half as fast, he said on a diesel you only ever see black smoke due to the egr and the black smoke you see is what a dpf catches. Sent from my SM-N9005 using Ford OC mobile app
#66 Storm16
Storm16
  • 55 posts
  • Name: M&S
  • Ford Model: Focus 1.8 TDCI Estate
Posted 02 December 2013 - 01:35 PM
well fitted my blanking plate at the weekend 20 mins later I was up and running over last 150 mile getting approx. 9 more mpg and no clouds of smoke nice!!!! car pulls smoother not so harsh and feels as though car is breathing better.
#67 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,043 posts
  • Name: James
  • Year: 2007
Posted 02 December 2013 - 04:05 PM
Another EGR Success :D
#68 Storm16
Storm16
  • 55 posts
  • Name: M&S
Posted 02 December 2013 - 08:35 PM
made me realise how my car was suffering before..lol  very :D now.... it sure is a egr success...
Not what you're looking for?
