the swan
Nearside Wing Panel Removal
hi,
ive had quite a nasty bump on my nearside wing and needing to replace it, is there any sort of guide or anybody know how to remove the panel and replace it with a new one?
Hi, did you find out how to remove the wing panel.
21 hours ago, shabazmo said:
Hi, did you find out how to remove the wing panel.Thanks
You might not get a reply! that member was last on the forum in November 2013.
Best just asking a body repair specialist, a quick call and they'll soon be able to tell you.
Thanks Mickey, but the side door window seems to hide a couple of bolts.  does the side window need to be removed.
only 1 bolt hidden, but you can access it with an open ended spanner, and give the bolt 1 turn anticlockwise, this will be enough to slide the wing out (the hole on wing is slotted
