salsheikh Posted November 11, 2013 Share Posted November 11, 2013 guys, is it possible to do? seen a loom from a mk1 focus and wanted to know if its possible to adapt this onto my focus 2.5? 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 11, 2013 Share Posted November 11, 2013 I dont see why not, I think the nozzles are the same, but you would need to install the additional wiring and run it through the headlining to the boot area? 1 Quote Link to comment Share on other sites More sharing options...
salsheikh Posted November 11, 2013 Author Share Posted November 11, 2013 Not too bothered about the rear washer. What about relays and wiring it into the fusebox or does it connect from the washer bottle onwards? Does £30 sound decent? 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 11, 2013 Share Posted November 11, 2013 to be honest, you could probably splice the loom of the heated windscreen, then just take the wire up to the jet... £30 doesnt sound too bad in all honesty! 1 Quote Link to comment Share on other sites More sharing options...
Preee Posted November 11, 2013 Share Posted November 11, 2013 The nozzles i think are on the same circuit as the rear demister and heated mirrors 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 11, 2013 Share Posted November 11, 2013 the rear isnt heated guys only the front washers ive had the rear nozzle out and its just a washer pipe into it 1 Quote Link to comment Share on other sites More sharing options...
leesheffield Posted November 11, 2013 Share Posted November 11, 2013 I had a bit of a frosty morning the other day and put on the heated windscreen to defrost it. (1st time I've done it since buying the car in summer) after a while I noticed the area round the wash jets on the bonnet was defrosted too. Now silly question but does this mean I already have the heated jets or was it just heat seeping through from the engine do you reckon? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 11, 2013 Share Posted November 11, 2013 It would suggest you have tgem pop the bonnet youll see the wires going into them Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 11, 2013 Share Posted November 11, 2013 Heated jets are very obvious. You'll see distinct wires coming from the underside. Rule of thumb is if you have a heated front screen you will have heated nozzles. It's called the climate pack. If you want to fit heated nozzles on a non climate pack model I'd say the best circuit to link to is the rear demister one as iy's set up for the heavier power load needed. Sent using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 12, 2013 Share Posted November 12, 2013 As above rear demister on the climate runs heated side mirrors front screen runs washer jets at the front Quote Link to comment Share on other sites More sharing options...
firefighter Posted March 14, 2016 Share Posted March 14, 2016 Is here any guide to fit heated washer jets?My car doesn't have the wiring Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted March 14, 2016 Share Posted March 14, 2016 Aftermarket would be easy but not necessarily clean. Sent from my GT-I9195 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 14, 2016 Share Posted March 14, 2016 When fitted from factory the heated nozzles run on the same circuit as quick-clear windscreens. It's both or neither from the factory. Probably far easier to install a heatshot system. Sent from my SM-G900F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
