When Put Head Lights On Engine Runs Really Rough, Help!!!
8 replies to this topic
#1 noahdom
noahdom
    Newbie
  • Budding Enthusiast
  • Pip
  • 4 posts
  • Name: matt
  • Ford Model: mondeo
  • Year: 2001
Posted 12 November 2013 - 04:16 PM
hi thx for reading, the problem I am having is on my mk3 mondeo zetec 2.0petrol (duratec) whenever I put my normal driving lights on at night the ngine begins to run really rough and if I don't give it more revs will surely cut out. however I can have main beam, a/c, heating on full plus wipers and this makes no difference to engines normal operation. also speedo and rev counter acting erratically and sometimes goes off briefly. I would be so grateful if someone could shed some light on my problem, as cant really afford to use a garage this near to xmas.  thankyou, matt
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,220 posts
  • Name: James
  • Year: 2007
Posted 12 November 2013 - 04:19 PM
It sounds to me like a potential battery issue. Visit several garages and ask them if they do a free battery health check. Have it tested and see what they say. Is it sidelights? or is it dipped beam headlights that cause the erratic behaviour? It could indicate a wiring fault...
#3 noahdom
noahdom
    Newbie
  • Pip
  • 4 posts
  • Name: matt
  • Year: 2001
Posted 12 November 2013 - 04:36 PM
dipped beam headlights, the side lights make no affect to the engine at all. I can have everything electrical on simultaneously apart from dipped lights and all is fine however if i just put the dipped lights on it causes the problem. could this still b a battery fault as i have a newish batt in garage i cud try. also engine management light comes on now and again since the problem started
#4 stooge75
stooge75
  • True Ford Enthusiast
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 12 November 2013 - 04:51 PM
you really need to get those fault code/s read as it'll be a good pointer to what's causing it. do you know anyone with a code reader? or elm327 cable etc?
#5 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,220 posts
  • Name: James
  • Year: 2007
Posted 12 November 2013 - 05:09 PM
It sounds like a wiring issue to me. Check the fuse boxes and ensure that they are both dry and there are no overheating wires.
Error codes are a good place to start, but right now, if you have a spare battery I would say there is no harm in fitting it to see if it makes a difference!
#6 noahdom
noahdom
    Newbie
  • Pip
  • 4 posts
  • Name: matt
  • Year: 2001
Posted 12 November 2013 - 07:56 PM
Thx very much for the advice will try the batt tomoz an if that fails will look for a diagnostic report, will get bac to u. Again thx
#7 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,220 posts
  • Name: James
  • Year: 2007
Posted 12 November 2013 - 09:35 PM
No worries :)
#8 noahdom
noahdom
    Newbie
  • Pip
  • 4 posts
  • Name: matt
  • Year: 2001
Posted 17 November 2013 - 09:08 AM
Tried batt no luck there also cam sensor
#9 Dan62
Dan62
  • 537 posts
  • Ford Model: Fiesta
Posted 17 November 2013 - 12:22 PM
Not what you're looking for?
