Fiesta water jet trouble
Started by helendempsey, Feb 22 2008 04:00 PM
7 replies to this topic
#1
Posted 22 February 2008 - 04:00 PM
Hi
On my fiesta the water jets arent working properly.
When i press the button on the wiper stalk the motor runs and lets a squirt of water through, then the motor stills runs but n owater comes out, is it blocked or has the motot gone
If i need to change the bottle how do i get to it as it seems to be in the wing
thanks
thanks
#2
Posted 22 February 2008 - 08:04 PM
Hi
welcome to FOC
Few things to check
1. You have water in the bottle
2. With a fine needle push the needle in the jets to unblock
3. check for air locks in the pipes (may be hard) You could try hot water the draw the air out of the lines. Try topping up to the top and leaving for an hour to see if their is a leak.
welcome to FOC
Few things to check
#3
Posted 25 February 2008 - 07:50 PM
Hi
Thanks for your reply, have done all of these but still doesnt work. What can I do next, and it seems the motor is still running.
Posted 25 February 2008 - 07:54 PM
Hi
Try and do it again making sure no water drips on the floor.. then try your pump out for a good 30 secs... see if any water comes out from below the car.. the hose may of detatched from the jet under the bonnet.
check this out.. looking for water coming out under the car too.
#5
Posted 26 February 2008 - 09:17 PM
Ive tried this and this doesnt happen. Any other steps, or what do you think is wrong with them
Thanks again
Thanks again
#6
Posted 27 February 2008 - 08:38 PM
ok.. are you able to get to the pipe under the bonnet? Perhaps blow down the pipe.
If this fails then I would say pump is the problem for sure.
#7
Posted 27 February 2008 - 10:38 PM
hi I've done all this. How do i take the pump off, and do i have to take the wheel off
Cheers
Cheers
#8
Posted 20 July 2008 - 04:42 PM
Also for future reference, check the bottle, if it has any 'black skum' around the insides then remove the pump and check its filter as a piece of the afore mentioned scum has probably detatched from the side of the bottle and been sucked against the filter stopping the waterflow!
