Comedy Of Errors And Now My Car Has The Judders!!
10 replies to this topic
#1 Smithler
Smithler
    Newbie
  • Members via FB
  • Pip
  • 3 posts
  • Name: Steve
  • Ford Model: Mondeo
Posted 13 November 2013 - 09:21 PM
Evening all,
I've a Ford Mondeo 58 plate 1.8 TDCI...the situation i have is that i recently ran out of derv, unfortunatley i was not able to make it to the petrol station (actually finally came to rest just the other side of it, about 50 meters short of making it to a pump). Needless to say diesel was put it, started straight up then fully filled as normal. About 300 miles down the car seemed to judder (what i would equate to a mis-fire) and the "Engine Malfunction" message on the Convers+ dash came up. I pulled over and left it for 5 mins and restarted...seemed fine and left it ideling over for 30 mins before setting off home.
Since then on 2 further occassions i have felt the same judder when accelerating under load and have taken it to the Allen Ford garage for the error codes to be checked.
The resulting message was "investigated eml on scan and found injector 4 open. closed circuit and low fuel level forced shutdown. codes not present all codes and road tested - ok for raod test customer to retry."
My initial thought was this could be related to me running it dry and crap getting through from the fuel tank and clogging up the fuel filter, but this should have been changed for new during full service a couple of months earlier.  So whats the chances of this getting clogged after 300 miles of driving since it ran dry?
Also i'm assuming the codes they read were actually from running it dry and not the EML coming on.
Any ideas or advice on what to check now...the car idles fine, accelerates fine...last judder was during a 50 mile trip, hit traffic and then upon pulling away the judder/mis-fire feeling again...i kept it at 6 in 4th (higher revs) to esnure the engine didn't labour...no EML coming back up yet either??
Got to say something just doesn't feel right, almost like its a little lumpy when accelerating at times under load.
Any advice would be welcome.
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,967 posts
  • Name: James
  • Year: 2007
Posted 14 November 2013 - 09:43 AM
The chances of the fuel filter being contaminated are almost 100%.
The sediment in the tank can be very heavy and the lack of fuel dredging it up and dumping it in the filter is almost guaranteed. What you will find now is that as the sediment will have also been resting in the fuel lines, so the sediment over the last 300 miles would have been further dragged into the filter, and as the fuel has flown through the filter it would have in essence brushed it all up into a wall and causing fuel starvation.
I think a new filter is a must and will have a very good chance of fixing your issue.
#3 slemon123
slemon123
  • Budding Enthusiast
  • 44 posts
  • Name: barry
Posted 14 November 2013 - 09:47 AM
+1
#4 stooge75
stooge75
  • True Ford Enthusiast
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 14 November 2013 - 03:41 PM
lets hope its your filter eh. get back & let s know if new one fixes it. this is another good reason for not letting the fuel system get so low,& always to drain the accumulated water from the bottom of the filter every now & then on diesel cars
#5 Smithler
Smithler
    Newbie
  • Members via FB
  • Pip
  • 3 posts
  • Name: Steve
Posted 15 November 2013 - 07:54 AM
Cheers guys, changing the filter at the weekend, lets hope its caked in crap so at least i might think i've found and resolved the issue.
#6 Smithler
Smithler
    Newbie
  • Members via FB
  • Pip
  • 3 posts
  • Name: Steve
Posted 17 November 2013 - 03:19 PM
Ok so fuel filter changed so now just waiting to see if anything occurs...the guys at the garage said it looked like it hadn't been changed within the last few months (question whether kiwk fit use genuine ford parts?) when I had full service. Took it away with me...filter is very black!
#7 stooge75
stooge75
  • 654 posts
Posted 17 November 2013 - 03:58 PM
sounds like its sucked all the crud out of fuel tank so could be your problem
#8 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 05:36 PM
There a PCM upgrade on some lynks engine for injector problem
#9 stooge75
stooge75
  • 654 posts
Posted 17 November 2013 - 05:45 PM
it was running ok before it ran dry
#10 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 08:58 PM
Yeah but it could be just new problem I would check for upgrade and have faults read first
#11 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,967 posts
  • Name: James
  • Year: 2007
Posted 17 November 2013 - 09:23 PM
Looking forward to some positive results with the new filter!
Not what you're looking for?
