Help End My Nightmare Before Christmas!! Idle Issue Fiesta 1.4 Zetec
Zetec 1.4 fiesta idle shaking
31 replies to this topic
#31 sazwahhh
  • Budding Enthusiast
  • PipPip
  • 15 posts
  • Name: Sarah
  • Ford Model: Ford Fiesta
  • Year: 2003
Posted 17 November 2013 - 03:32 PM
Ok so start with:
HT Leads
Clean idle control valve
Reset base setting of throttle butterfly.
See if that works if all else fails..
Temp sensor
02 sensor (is this the lambda sensor?)
Thanks :) your a star!! I will update in the week hopefully can find a decent mechanic now!
Have something to contribute?
#32 wase16ll
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,135 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 17 November 2013 - 03:44 PM
your jumping the gun
you 100% need to know if engine is misfiring
if it is then your looking at..
coil pack
ht leads
(start from scratch, dont dismiss anything thats been already changed, faulty new parts/poor workmanship is far too common)
if it isnt misfiring...then an idea of where to look..bearing in mind this can be a lot harder to trace and ideally needs to be done with diagnostics/live data and somebody that knows what they are doing with it ;)
get those emissions tested first as that will narrow things down
idle air control valve
butterfly base setting (should never be touched, but going on the previous bodges, may well have been tampered with)
02 sensors
air leaks
cam sensor
also not forgetting poor wiring/connections are common on focus
Not what you're looking for?
Also tagged with one or more of these keywords: Zetec, 1.4, fiesta, idle, shaking
