D13 HPD 95
Lookwood Dial Kit
evening all i received my look wood dial kit today in the post for the mk7, does anyone know how to get the speedo unit out so i can replace the dial's?? cheers
If it's the same as the Focus , then lift the cover above the steering column , there you should see two Usually T20 hex screws , remove then , drop the steering wheel down and pull on the cluster , it should come out and then un-clip the wiring
Its the section between the dials and the top trim of the steering , yes it just lifts up. (Not the top of the steering cowling)
It just sits there you can use your fingers to pull it up, if its the same as the Focus
The bit of dash trim above the steering wheel below the clocks, pull it directly towards you, that reveals 2 screws you need to take out.
At the top of the clocks, the 'ceiling' in front of your trip computer has a round circle cover that can be levered out with a tiny flat head screwdriver. That's the 3rd screw under there that you need to take out.
Then pull clocks towards you :)
looks really good , nice one , did you have line up the needles afterwards ?
Yh just plugged it all back in started the car and then adjusted them as it needed to be, also toke the car for a drive and tested the speed against my tom tom and its a lot closer now used to be around 5-8mph out but dead on nearly now happy with it :)
Easily done then i will take a look see if they make them for the FF3
Yh toke 20mins thats all :) showed my dad and my m8 they both have now ordered one for theres lol, dad has the focus and m8 has an st fez :)
Need a night time pic now m8 ;-)
