Wet Carpets
17 replies to this topic
#1 roosterbooster
roosterbooster
    Newbie
  • Budding Enthusiast
  • Pip
  • 9 posts
  • Name: rooster
  • Ford Model: ford mondeo st tdci
  • Year: 2006
Posted 17 November 2013 - 05:23 PM
Hello, my passenger rear carpet behind drivers seat was soaking wet last week so i opended the door and poured water from a watering can over glass and weather strips to check where water was coming in and the water was going into door as it should and running out the drain holes at the bottom of door, but when i checked the metal locking mechaniam water was coming out of it when puring water over windows so thats where the water is getting in, does anyone know a fix for this ? thnx,, Russ
Have something to contribute?
#2 mick85
mick85
  • True Ford Enthusiast
  • 924 posts
Posted 17 November 2013 - 05:29 PM
Has ur car aircon
#3 stooge75
stooge75
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 17 November 2013 - 05:41 PM
put new weather strips/seals in mate. nowt to do wi aircon
#4 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 05:57 PM
Yeah but there a leak off pipe on air con underneath carpet beside clutch sometimes they leak into back driver side makin rear carpet wet
#5 roosterbooster
roosterbooster
    Newbie
  • Pip
  • 9 posts
  • Name: rooster
  • Year: 2006
Posted 17 November 2013 - 06:00 PM
hi thanks for the replys, yes it has air con mike85 like just about all mondeos but how would that make water come through lock mech ? stooge75 are the weather strips easy to fit along window ? would you replace top ones aswell.. i also have chrome trim andjust been looking for some on the bay but no joy
#6 roosterbooster
roosterbooster
    Newbie
  • Pip
  • 9 posts
  • Name: rooster
  • Year: 2006
Posted 17 November 2013 - 06:05 PM
mike86,,o right i didnt know that thats somthing to be aware of, thnx, its 100% coming from the door tho water was running down above arch shape and then down and coming over bottom rubbers on floor near carpet
#7 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 06:07 PM
Sorry bud misread ur question so were exactly do u think water comin in there a seal on body frame and seal on door which should stop water from lock comin in car
#8 roosterbooster
roosterbooster
    Newbie
  • Pip
  • 9 posts
  • Name: rooster
  • Year: 2006
Posted 17 November 2013 - 06:13 PM
water is coming out of the lock near where the child lock switch is and then hits the body work then runs down panel inbetween door and body work the biulds up and splashes over and spills onto carpet
#9 stooge75
stooge75
  • 654 posts
Posted 17 November 2013 - 06:17 PM
my door seal needs replacing also. they just push fit on. also,the strips along tops of doors where window is ,also pushes/slides on so im told,but ive never replaced one yet either.(going to though soon). I think I'd use some loctite/araldite also just to keep it snug & tight.
also,theres a sound deadener card thing in the door (on some cars)that for whatever reason folk damage & fail to replace. might be a good idea to have a look
#10 roosterbooster
roosterbooster
    Newbie
  • Pip
  • 9 posts
  • Name: rooster
  • Year: 2006
Posted 17 November 2013 - 06:29 PM
yes i replaced that membrane in all of my doors when i first bought the car due to a hole in the stuff, it is a very common problem, i took the origanal stuff out and replaced with clear plastic all over openings in inner door and sealed and fixed down with butyl tape, i will be on the hunt for some weather stripes now then might try scrap yard or try buying new if there not to expensive i will let you know how i get on with replacing,
#11 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 06:32 PM
I have replaced lots seals on door frame just tap them on wit rubber mallet but they ain't cheap from ford door weather strips at window just push on no sealer needed
#12 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 06:34 PM
Worth cleaning drain holes on door to
#13 roosterbooster
roosterbooster
    Newbie
  • Pip
  • 9 posts
  • Name: rooster
  • Year: 2006
Posted 17 November 2013 - 06:35 PM
sounds easy enough, i will start with the weather strips on the window and door
#14 stooge75
stooge75
  • 654 posts
Posted 17 November 2013 - 07:02 PM
yeah suppose so. mick how much did ford charge for them,as Ford sell them to dealers at 2 euros each.cant wait to see how much of a mark-up the dealers put on eh
i get a feeling the mcat is wrong & maybe the decimal is in wrong place lol.maybe supposed to be 21 euros each maybe? because the short lower seal on the door is 20 euros as well
#15 mick85
mick85
  • 924 posts
Posted 17 November 2013 - 07:12 PM
Weather strip under window bout 20 or 30 an when u open door big seal on body of car not the between 50 an 100 an seal on inside door not sure bud
Not what you're looking for?
