AJRTDDI
Does The Mk1 Ghia Tddi Have Abs ?
from standard no you dont have abs when you say abs light are you meaning on the dash test as all cars with abs or not will do that if you did have abs it would work or the error light will stay permenantly illuminated on the dash if thats the case it could be a great many things from sensors to broken wires to a faulty pump
If the light is on then you do indeed have a car equipped with abs but as the light is illuminated your abs will not function. (we have had 2 non abs focus' and neither of them had an abs light)
If there are no errors then its going to be a hit or miss to what the problem is. I have found water ingress in connectors under the car to be a common annoyance on other makes of cars.
Hey guys.
The abs light comes on when i turn the key to start the car. But go's off when engine is started.
If i look under the car and have VR/Hall effect sensors on the driveshaft/Hub i guess i do have abs ?
Hey guys.
Sorry I completely misread your first post.
Yes you do indeed have abs. You say it's not working, are the wheels definitely locking up?
