Coolant Temp Gauge
6 replies to this topic
#1 golfpaul
golfpaul
    Member
  • Budding Enthusiast
  • PipPip
  • 26 posts
  • Name: paul
  • Ford Model: mondeo
  • Year: 2001
Posted 29 November 2013 - 02:03 PM
Hi all.
2001 2.0 tdci
The coolant temperature never passes the 1/4 mark on the gauge - where would you advise looking first?
Could it be a dodgy sensor?
Have something to contribute?
#2 jamesm182
jamesm182
    Management
  • Admin
  • 1,493 posts
  • Name: James
Posted 29 November 2013 - 03:53 PM
Thermostat?
Half way seems to be the norm for the cars I have had. Welcome to the club by the way!  :)
#3 stooge75
stooge75
  • True Ford Enthusiast
  • 654 posts
  • Ford Model: Mondeo tdci zetec
Posted 30 November 2013 - 05:19 PM
when your car is running ,say on motorway does it still only sit at quarter way up?
#4 golfpaul
golfpaul
    Member
  • PipPip
  • 26 posts
  • Name: paul
  • Year: 2001
Posted 30 November 2013 - 08:16 PM
Hi, no never goes above about a quarter.
The heaters are hot also.
Was thinking the sender, are they prone on this model.
Could it be the thermostat.
thanks in advance
#5 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 01 December 2013 - 01:58 AM
Hi all.
2001 2.0 tdci
It could not be a dodgy sensor - the cooling system is a traditional mechanical pump with a thermostat
there is a second (small) thermostat for the oil cooler, it comes off the waterpump casing - if it jams open it can cause serious overcooling
there is also an electric heater in the hose to the cabin heater
these engines take a long time to warm up in cold weather,/ are overcooled  especeally with the heater on (can take a lot of heat out of the system) and if its being driven sedately
#6 golfpaul
golfpaul
    Member
  • PipPip
  • 26 posts
  • Name: paul
  • Year: 2001
Posted 01 December 2013 - 10:28 AM
When i said sender, i meant the coolant temperature sensor indicating an incorrect temperature.
what's the best way of diagnosing this issue?
cheers
#7 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 09 December 2013 - 09:04 AM
cheers
The temprature sensor reads the temprature of the head (the metal of the head) it sends this to the ECU and temp gauge, chances are it is working perfectly, and the low temp readings are from ACTUAL low temp readings,
the main thermostat controls the water temp
you could fit a water temp gauge so you would then know the water temp, seperate/ indipendant  from the one on the dash
Not what you're looking for?
