AdBlock Warning
focusdriver
Adjust Windscreen Washer Jets
4 posts in this topic
The driver side - RHS spray is going too far right. I thought these could be adjusted by using a needle (last time was on my G reg focus..!), but it appears not.
Is there no way of adjusting the spray?
TIA
Stick a pin or needle in it and drag/pull/lean in tge direction you want it to go then pull out the needle
If it's mist washers then they aren't adjustable.
I used a thin blade screwdriver, point in and gently pushed. Took a bit of arranging but got there.
