kennymcd
Battery Light Staying On Ford Fusion 2006
Hi, I have a Ford Fusion 2006. The battery light stays on when the engine is running. I have checked the charging voltage and it is 13.5 volts. Anyone any idea what is keeping this light on. Thanks
Bad battery? I know my voltage fluctuates between 14.2 to 14.6 volts. (Scangauge II and Torque Pro.)
Had the same issue, but on my focus. battery and alternator tested and were spot on, turned out a wire had corroded in engine bay. Not sure which one but mechanic sorted it fairly quickly, so couldn't have been too difficult to locate! :)
