Mk1.5 Focus Will Not Rev When Warm
88 replies to this topic
#31 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,468 posts
  • Name: James
  • Year: 2007
Posted 11 December 2013 - 05:41 PM
Not bad at all!
Have something to contribute?
#32 Blackie_No1
Blackie_No1
  • Budding Enthusiast
  • 120 posts
  • Name: Brian
  • Ford Model: Mondeo Si 2.0 16v
  • Year: 2000
Posted 11 December 2013 - 05:46 PM
If its cured, yes lol
Sent from my GT-P3100 using Ford OC mobile app
#33 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 14 December 2013 - 06:18 PM
Ok, not cured. I put £30 of fuel in the car after it was worked on which took it to just below half full. I've driven 96.6 miles and it has gone just below a 1/4 full again and it's started all over again, though this time I didn't switch the car off, just let it idle for a few mins. Bit of a scattery vid here but hopefully you get the point. At the start before I put the hazards on the accelerator is flat to the floor! It then gets to the point where it nearly dies, so I stop the car and get out and try to get a clip of the exhaust note.
#34 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 15 December 2013 - 01:00 PM
I'm going down wase16ll's route and going to dismantle the exhaust system today. The cat I've been told is hollowed out, but I'll find out for sure later, though I'm not so sure based on the evidence of a blowout between the manifold and the cat.
#35 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 15 December 2013 - 03:10 PM
First off, the cat, well not so much off as in dropped from manifold, defo not it, it has indeed been hollowed out due to it collapsing in the past:
DA0D9F45-23A3-4EB2-8EE2-E7CC1F16A2D5_zps
Had to stop as I'm working outside and the rain has got just to much :(
#36 wase16ll
wase16ll
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 15 December 2013 - 05:45 PM
as i understand it...you had 02 sensor changed, drove 90 miles before problem reoccured
was that in a single journey?
also, this time, you didnt switch off, let it idle for few minutes, then found the power returned?
blockage is still a possibility, so still worth carrying out checks for it...but if you can get hold of a tester, may be worth carrying out a fuel pressure test, you might have a problem with the pump
#37 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 15 December 2013 - 05:52 PM
No it was from Wednesday to yesterday, to and from work mainly, 13+ miles each way.
Yea, I just let it tick over for a while before driving on.
#38 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 15 December 2013 - 06:57 PM
exhaust blockage or fuel pressure problems, including a blocking filter, could give you these symptoms without flagging any codes/faults
could also be a problem with maf sensor, but would be unusual for that to happen and not flag anything.
may also be worth testing throttle position sensor, reasonably easy test if you have a voltmeter
#39 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 15 December 2013 - 07:17 PM
Nope but can get my hands on one easy enough, what shouldmi be doing with it?
#40 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 15 December 2013 - 08:08 PM
Got the front pipe separated from the middle exhaust section. I was able to see up the first (essentially straight through silencer) to the bend and no sign of blockage, not sure of the second silencer yet, but I have a feeking it isnt blocked.
#41 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 15 December 2013 - 09:01 PM
problem with the silencers is you wont see through them anyway...ideally to test for blockages is what i wrote a few posts back or find someone with a back pressure tester.
if you can get hold of a fuel pressure tester, you connect it to the schraeder valve on the fuel rail and read the pressure at idle with pressure regulator vacuum disconnected..should read approx 4 bar, with vacuum connected and assuming the vacuum is good (approx 5psi) pressure should read approx 3.5 bar
the TPS should be a 3 pin sensor...disconnect and connect an ohm meter to the outer pins (1 and 3) of the sensor, approx just under 4k ohms
connect ohm meter to pins 2 and 3
with butterfly closed..approx 4.2k ohms, butterfly fully open, approx 1,2k ohms...but its vitall that the resistence reading is a smooth curve from closed to open and back, so operate the butterfly slowly and watch for any sudden jumps/drops in readings as that will indicate a faulty sensor.
may pay to renew the fuel filter anyway, but at least diconnect the filter and drain it to see if the fuel is coming out clean
#42 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 15 December 2013 - 09:03 PM
Yea, gonna replace the filter just to see as you say
#43 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 17 December 2013 - 09:13 PM
Someone has suggested a coil pack, what's your thoughts wase16ll?
#44 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 19 December 2013 - 09:27 PM
going by the fact you believe there is no misfire when power drops, its unlikely.
if there is a misfire thats bad enough to virtually bring the engine to a halt, will almost certainly have set a code and flagged a light
#45 Blackie_No1
Blackie_No1
  • 120 posts
  • Name: Brian
  • Year: 2000
Posted 19 December 2013 - 09:31 PM
Yea that's sort of what I was thinking. No miss firing or hesitations at all, just a sudden loss of power and will not accelerate/rev.
I can't get anyone here in N.ireland who can pressure test the exhaust, but I stuck an airline down it and there felt like a good flow, so I don't think it's it.
Not what you're looking for?
