Temperature Guage
12 replies to this topic
#1 mondeo zetec
mondeo zetec
    Member
  • Budding Enthusiast
  • PipPip
  • 27 posts
  • Name: sean
  • Ford Model: mondeo zetec
  • Year: 2009
Posted 07 December 2013 - 05:19 PM
hi guys could someone please tell me where exactly should the temp gauge sit at running temperature..?
mine seems to wander between 70 and 80 ish degrees....
im wondering if this is correct
car is a mondeo 2.0 duratorq 2009 estate
Have something to contribute?
#2 mondeo zetec
mondeo zetec
    Member
  • PipPip
  • 27 posts
  • Name: sean
  • Year: 2009
Posted 08 December 2013 - 06:08 PM
anyone have an idea please
#3 adambell
adambell
  • 294 posts
  • Name: Adam
  • Ford Model: Mondeo Titanium X Business Edition
  • Year: 2014
Posted 08 December 2013 - 06:16 PM
It should be right in the middle of the gauge mate, it will vary a little bit but not too much
#4 mick85
mick85
  • True Ford Enthusiast
  • 924 posts
Posted 08 December 2013 - 06:43 PM
Check coolant temp sensor with multimeter
#5 mondeo zetec
mondeo zetec
    Member
  • PipPip
  • 27 posts
  • Name: sean
  • Year: 2009
Posted 08 December 2013 - 09:04 PM
where on the mondeo 2.0 duratorq is the cts please..?
what value should it read..on a multimeter
the display varies as mentioned between 70 and just over 80 up and down quite alot lower reading more than high..
any help on the subject would be much appreciated guy's
cheers
#6 mick85
mick85
  • 924 posts
Posted 08 December 2013 - 09:53 PM
U need back probe sensor an check resistance I will get u exact readings an location later it's most likely in cylinder head at side above gearbox or some measure coolant and some measure temp of the metal
#7 mondeo zetec
mondeo zetec
    Member
  • PipPip
  • 27 posts
  • Name: sean
  • Year: 2009
Posted 08 December 2013 - 09:55 PM
if you or anyone can update the location of the coolant temp sensor this is great thank's chap's
any pic's of its locality as well is good
cheers regards sean
#8 mick85
mick85
  • 924 posts
Posted 08 December 2013 - 10:07 PM
I would also be checking if water pump work ok does ur fan be coming on more then usual leave ur car idling an see if it starts overheat an open coolant cap see is water been pumped around but be carefull never open cap under pressure on hot engine if u don't have much knowledge wit cars
#9 mondeo zetec
mondeo zetec
    Member
  • PipPip
  • 27 posts
  • Name: sean
  • Year: 2009
Posted 08 December 2013 - 10:13 PM
i do have quite a lot of knowledge just not on this mondeo,,, the car fan does not come on alot and water is being pumped ok..!!
#10 mick85
mick85
  • 924 posts
Posted 08 December 2013 - 10:17 PM
Grand just didn't want u end up scalded cause me lol well then temp seņor be next think if u had good fault code reader with live data most them tell u the temp so this would tell u exact degrees it thinks it is handy for cross referencing ur testing of sensor wit meter
#11 mondeo zetec
mondeo zetec
    Member
  • PipPip
  • 27 posts
  • Name: sean
  • Year: 2009
Posted 09 December 2013 - 08:35 AM
any further help with this problem i am experiencing guys..??
#12 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 09 December 2013 - 09:21 AM
That seems normal - the temp is about avarage for the type of car and it can fluctuate up and down as the thrermostat opens and closes through its cycle
#13 mondeo zetec
mondeo zetec
    Member
  • PipPip
  • 27 posts
  • Name: sean
  • Year: 2009
Posted 10 December 2013 - 10:12 AM
this is correct then..? could anyone tell me the actual temperature on a diagnostic program please..?
Not what you're looking for?
