* * * * * 2 votes
Phoebe The Mk7 S1600 (Pic Heavy)
172 replies to this topic
#151 Merv130
Merv130
  • Budding Enthusiast
  • 212 posts
  • Name: Norman
  • Ford Model: Ford Fiesta s1600
  • Year: 2011
Posted 20 July 2014 - 09:58 PM
Where did you bought the fog caps?
Enviado desde mi Nexus 5 mediante Tapatalk
 these?
off ebay.de the german ebay
Have something to contribute?
#152 alanmx
alanmx
    Member
  • PipPip
  • 11 posts
Posted 20 July 2014 - 10:10 PM
Thanks from the answer, your car really kills me
#153 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 21 July 2014 - 11:28 AM
no problem mate  :)
#154 Will-MK7
Will-MK7
  • 237 posts
  • Name: Will
  • Ford Model: Fiesta S1600
  • Year: 2011
Posted 21 July 2014 - 04:35 PM
The cat back you can pick up for around £200 second hand, and it means you can upgrade to the rest later on if you want
I was hoping to be paying around that tbh it's just waiting to find one :(
Them smoked fogs look smart as well!
Cheers for your help mate.
#155 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 24 July 2014 - 07:33 PM
this is probably the biggest update I have had so far, purchased a set of new (well second hand) wheels!
the night I got them
I washed, detarred, iron clensed and used the below on them before I put them on the car, hopefully brake dust shouldn't be a problem for a while
#156 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 24 July 2014 - 07:34 PM
streetpacks and spacers off, new wheels on
I'll hopefully get a few better shots when the car is clean and I can rope a mate into taking some proper photos not off a phone camera.
well pleased with them though
#157 luke.grimbley
luke.grimbley
  • 220 posts
  • Name: Luke
  • Ford Model: Focus Titanium 2.0
  • Year: 2009
Posted 24 July 2014 - 10:34 PM
Love the wheel's. Very clean, especially for second hand.
#158 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 24 July 2014 - 10:55 PM
cheers bud, yeah they are only 4-5 months old so they are in really good condition.
They are sitting better now the springs have settled down a bit again, i'm really happy with them
#159 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 31 July 2014 - 11:36 PM
So this update is basically me fixing a few **** ups I made previously. I bought cheap chinese HIDs for my fog lights and it should really come as no surprise that they let in condensation. This was really annoying me as it looked awful
so i set about taking the fog lights out and getting rid of the condensation that had built up by shaking out as much as I could
then using a hairdryer to dry out the rest.
The HID bulbs went straight in the bin and I purchasd some 50w Cree LED fog light bulbs.
Fitted, such a difference with no condensation, looks far better! time will tell if the LEDs are up to scratch
#160 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
the second mistake I made was to buy the wrong HID bulbs for my new headlights, I assumed the dipped beam was the same bulb as the full, and I was wrong! so I finally got the right set (no chinese cheap ones this time) and set about fitting them. this is going to be a bit long winded for those that know how to fit these but I was asked to make a bit of a guide by one of the guys who bought the same lights so here it goes.
first of all remove the rear cover off the dipped beam and disconnect the wires from the bulb, you will need to pull of the rubber gromit around the wires and push them through the hole so you can take the cover off completely
The next step is to drill a hole in the cover for the wiring for the HIDs. A normal drill will do, but I do recommend getting a stepped drill bit as it made this step very easy
the next step is to feed the wiring through the hole making sure to fix the grommet in place so no condensation will form. the original light wires will also need to be refitted.
out with the old bulb, in with the new
#161 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 31 July 2014 - 11:37 PM
fit the bulb in place using the spring clip and connect the hid wires to the original connectors, put the cover back on and it should look like this from the outside
then it is a matter of finding a place to fit the ballasts. I originally cable tied them to the car as below
but I wasn't happy with it as the wires weren't really long enough and it meant disconnecting them every time I wanted to remove the headlight. So I purchased some heavy duty velcro and stuck the ballast onto the bottom of the light unit...
now all that is left to do is connect the wires to the ballast and refit the light.
before shot
after shot
with the new led fogs on
and a rather rubbish night shot to give a bit of an idea of what they are like
#162 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 04 August 2014 - 11:21 PM
so spent all day on the car today fitting amplified sound system in the car, first step was to strip out the interior
I then bought an SOT lead and adapted it using RCA adapters, I could have done it without the SOT lead but it means I didn't have to cut the original cables.
#163 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 04 August 2014 - 11:22 PM
Rear speakers out and new ones in with new speaker cable running to the amp
front speakers got the same treatment with component speakers
tweeters
crossovers stuck onto door trim using heavy duty velcro and wired up.
and speaker wires ran through the door loom
#164 Merv130
Merv130
  • 212 posts
  • Name: Norman
  • Year: 2011
Posted 04 August 2014 - 11:23 PM
power cable ran through the grommet shown here
I ran the remote wire to a fuse tap in the fusebox, forgot to take a photo.
in process of wiring up the amp
and finished
now I have put everything back together i'm really happy with how tidy it all is, you would never know there is an amp hidden under the seat and the sound quality is far better.
But I have interference when the car is running which isn't there when the ignition is on. I think I need a better ground, I ran it to one the bolts for the handbrake which I think was a mistake. I'll change it to a seat bolt and make sure it makes good contact to see if it gets rid of it
#165 Lenny
    Retired Moderator
  • 10,666 posts
  • Ford Model: Focus ZetecS
Posted 05 August 2014 - 12:01 AM
Excellent work done mate, you have gone to great lengths making a very tidy job of everything
Not what you're looking for?
