Coolant/ Radiator Sensor Faulty?
6 replies to this topic
#1 Timbo
Timbo
    Member
  • Budding Enthusiast
  • PipPip
  • 17 posts
  • Ford Model: Mondeo LX 1.8
Posted 09 December 2013 - 02:19 PM
Hi all. I recently had the thermostat replaced in my 1.8 petrol Mondeo, as the heater was taking ages to get warm enough, although the temp gauge climbs to 90 degrees fairly quickly.
The garage said that my radiator fan is coming on at only 89 degrees, which may show why the heater isn't great! The temp gauge doesn't change when the fan comes on either, as you may expect it to do.
Is there a combined sensor on these cars, as that could provide a reason for these faults, or are they all separate? ie Radiator fan sensor, coolant temp sensor etc.
Many thanks
Tim
Have something to contribute?
#2 mick85
mick85
  • True Ford Enthusiast
  • 924 posts
Posted 09 December 2013 - 03:45 PM
There coolant temp sensor an ecu controls fan coming on have u checked water pump is pumping properly
#3 Timbo
Timbo
    Member
  • PipPip
  • 17 posts
Posted 09 December 2013 - 03:54 PM
Hi, thanks for the reply. If the pump wasn't working, I would expect the car to show signs of over-heating. The fan is coming on before the thermostat has even opened properly at the moment.
Cheers
Tim
#4 mick85
mick85
  • 924 posts
Posted 09 December 2013 - 04:01 PM
We'll thermostat open between 83 an 89 don't have exact figure an if u not good heating indicates a blockage possibly partially blocked matrix that why fan cutting in early bad circulation possibly but coolant temp sensor or ecu also could be at fault
#5 Timbo
Timbo
    Member
  • PipPip
  • 17 posts
Posted 09 December 2013 - 05:31 PM
Thanks!
Tim
#6 mick85
mick85
  • 924 posts
Posted 09 December 2013 - 05:53 PM
Let us know the outcome be interested to know
#7 Timbo
Timbo
    Member
  • PipPip
  • 17 posts
Posted 09 December 2013 - 06:11 PM
Will do, probably do the coolant sensor first, as it's the cheapest option!
Cheers
Tim
Not what you're looking for?
