sas
Abs
if you cut the abs wire by accident could it affect the running of the car thx
well your abs wont work and it will chuck an error light on your dash and log a code. Car itself will run fine though.
had a garage out they said low fuel pressure put a new filter on got running same problem keeps cutting out done a code read would not read it sp[ent the last week trying tro fix to no avail got garage out again today to do code read unable to read he said why is the abs light on some idiot done wheel bearing on it and cut the wire that is why i asked the question in the previous post still cant get the codes read for love nor money so got new management box as told by someone else spent all day fitting it and key sensor on steering column and chip in key still the same thanks for your quick response higgsy thx
low fuel pressure suggests the pump is gone mate changing the filter wont help much with that you sure these guys even know what they are doing a new ecu will need coded to the car along with all the keys etc ide get a different mechanic to be honest with you
(thanks for your quick response artscot79) the first garage that came out said it was low pressure but he could not get his code reader to read the codes he just guessed it was low pressure the second garage could not get the reader to read codes either he said it could be a faulty injecer or heat plugs _why cant they get there code reader to read he code car ticks over fine when you drive it conks out thx
I had low fuel pressure fault on code reader a while back.was resolved with fuel filter change..but obviously you have done this already.
