I have a 59 reg ford mondeo diesel 2.0 l estate with 102000 miles on clock when should the cam belt be changed presuming it has a belt or is it a chain
Better get it replaced at 80K as then you get it done sooner, it massively reduces the risk of something going wrong (snapped belt), I would suggest you get it done sooner rather than later, and it might be worth replacing the water pump whilst your at it, as you need to take the belt off again when you do the pump (if / when it goes)
Get it done ASAP, mine snapped on my mk1 focus and it cost me £1,100 to get it fixed, it's not worth the risk.
