Led Cabin Light Problems..
20 replies to this topic
#16 Mikey923
Mikey923
  • Budding Enthusiast
  • 214 posts
  • Name: Mike
  • Ford Model: Fusion 1.4 TDCI
  • Year: 2004
Posted 01 January 2014 - 04:04 AM
The first pictures are when the doors are closed
Have something to contribute?
#17 rhys1606
rhys1606
  • 68 posts
  • Name: rhys
  • Ford Model: fusion 2
  • Year: 2003
Posted 01 January 2014 - 09:46 AM
Yeah that is exactly what all of mine have done no matter what type of led bulb it is ......
Sent from my Hudl HT7S3 using Ford OC mobile app
#18 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,760 posts
  • Name: James
  • Year: 2007
Posted 02 January 2014 - 01:53 PM
It sounds like there is too much residual power running around the electrics which the LED is using to power from.
#19 Mikey923
Mikey923
  • 214 posts
  • Name: Mike
  • Year: 2004
Posted 02 January 2014 - 02:14 PM
Anyway to stop this?
#20 gbmkb
gbmkb
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: bob
  • Year: 2003
Posted 11 June 2014 - 12:13 AM
The problem of glowing LED bulbs is one I have encountered on cars with interior lamps with a delay circuit.
The delay system causes a small residual current to be present at the bulb even when the lamp is 'off'
Normally, the tungsten bulb has enough resistance to prevent the glowing when the circuit is 'off'.
However, LEDs have very little internal resistance and so glow slightly even when the delay timer is 'off'.
I have cured this in the past by soldering a small 'Grain of Wheat' bulb (as used by modellers and which is rated at less than 0.5 watt) across the LED bulb. (Make sure the bulb is 12 volt as they come in various voltages)
This is just enough resistance to control the residual current and stops the LED glowing.
It should be enough to do this to just one of the bulbs if you have a system with more than one interior lamp controlled by the delay unit.
#21 fusionfan2
fusionfan2
  • 73 posts
  • Name: Ben
  • Ford Model: Fusion 3 1.6
  • Year: 2002
Posted 11 February 2015 - 10:12 PM
I've put a canbus LED in the overhead courtesy light, and it works fine and turns off completely....
One of these:
http://www.ebay.co.u...=STRK:MEBIDX:IT
Not what you're looking for?
