ian610 Posted December 16, 2013 Share Posted December 16, 2013 Coming home from work on Tuesday, all was well. Get in the car the next day, move off and get on the road, and the gears were suddenly really resistant and needed a lot of force to shift. I can still drive it, but as I say, it just takes a lot of effort to move the stick. Doesn't grind at all, apart from reverse on occasion. There also seems to be a new rattle/tapping sound that appears when the clutch is pressed down (thrust bearing?). Haven't really noticed any slip and the bite seems as good as before. Clutch/brake fluid level ok. Gears move fine with the engine switched off, but not when its on. 54 plate with 59k. Anyone know for definite what the cause is? Is the clutch gone/on the way out? Quote Link to comment Share on other sites More sharing options...
Sparticus89 Posted December 17, 2013 Share Posted December 17, 2013 Had exactly the same problem with my 54 plate Fiesta Finesse (60k on the clock). There is a known fault with Fiesta's cylinder rod not connecting to the pedal correctly. A quick google search and you will see lots of people on different forums with the same problem. See here ---> http://www.rac.co.uk/forum/showthread.php?6261-56-Plate-Ford-Fiesta-Clutch-Gear-Problems http://www.rac.co.uk/forum/showthread.php?15596-fiesta-clutch-issue Ford dealerships should be able to provide a clip that will keep the pedal line with the master cylinder. Pop your head under the steering with some cable ties ready (and a torch) if there is a plastic cone to your right going into a cylinder. If it's not going into the cylinder when you press the clutch down use a cable tie to align them. Cable ties are just a quick fix, I'd recommend using a bolt through the clutch pedal (there should be a hole for one anyway) to keep things nice a secure.p.s I am not a mechanic so I'd expect someone will correct my terminology, I will post some pictures of mine if that helps. Will get the camera out tonight. M Quote Link to comment Share on other sites More sharing options...
ian610 Posted December 17, 2013 Author Share Posted December 17, 2013 Thanks for the reply. A picture would be appreciated for reference. I read about the cylinder rod issue before I bought the car so was prepared, and promptly secured it with a cable tie. I've driven the car for 2000 miles with it like that and its been fine. Drove it to work and back one day and was completely fine, then I go to drive it the next day and it was a suddenly a bag of crap; changed 'just like that' overnight. No warning or prior symptoms to indicate otherwise. Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 17, 2013 Share Posted December 17, 2013 I say your clutch is gone u can still change gear on a car without a clutch this is safer the slamming into gear I seen people wrecking input shaft in gearbox by slamming into gear best getting it sorted now Quote Link to comment Share on other sites More sharing options...
