aeaguilar
Focus Problem
Hi! I have a ford focus 1.8 2005 model. My problem is when i start the engine my headlights are flashing, maybe like 2 or 3 flickers then it stops when the engine is running.. Can it be connected to the alam system of the car? Pls help! Thanks!
sounds like your battery is dying will likely need a replacement, so you will need a silver calcium replacement
sent using the Ford OC app for android.
Its quite probable to be honest. Even if the battery reports its OK, it could still have a warped cell, so I would prepare a backup plan in case you dont purchase a repacement battery.
