markw96 Posted December 17, 2013 Share Posted December 17, 2013 HI, I have recently had a new clutch & master slave cylinder fitted. Noticed the other day that my reverse light is not working as my parking sensor did not go off when reverse was selected. I have checked the wires and there is no power going to them at any time even when the car is in reverse. I have checked the fuse under the glovebox and that was fine. I naturally assumed it was the reverse sensor located on the gearbox so I fetched one of these to day and replaced it. The only problem is I still don't have power to the back of the car. I crossed over the feeds on the clip to the reverse sensor and it was both sides indicating no problem there, yet I still cant get it to work. Any suggestions please? Quote Link to comment Share on other sites More sharing options...
dezwez Posted December 17, 2013 Share Posted December 17, 2013 I check the wire to the gear box hasn't been broken with the weight of the box on it Quote Link to comment Share on other sites More sharing options...
markw96 Posted December 17, 2013 Author Share Posted December 17, 2013 what would be the best way to get to it? where does it run? and thanks Quote Link to comment Share on other sites More sharing options...
dezwez Posted December 17, 2013 Share Posted December 17, 2013 from the loom in engine bay down to the gear box if it been broken you would be able to see it. Check its might pay to check it with a test meter take a look in Haynes manual for wiring diagrams Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 17, 2013 Share Posted December 17, 2013 You will get better access if you remove the air filter housing. Quote Link to comment Share on other sites More sharing options...
markw96 Posted December 17, 2013 Author Share Posted December 17, 2013 I've ready had the air filter housing out to change the sensor, the wire looked fine from what I could see and there was power to it because I tested it. Where else can I look? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 17, 2013 Share Posted December 17, 2013 Was the switch a new one? Is the plug connected firmly and free of corrosion? The plug is pretty exposed and can get corrosion on the contacts quite easily. Quote Link to comment Share on other sites More sharing options...
markw96 Posted December 17, 2013 Author Share Posted December 17, 2013 Yeh the switch was new direct from fords, the plug also looked fine. I tested one side of the plug for power and it was live, so I ran some wire from one side to the other to complete the circuit and they both came up as live. Yet their is still no power going to the rear, I can't work it out myself! :( Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 17, 2013 Share Posted December 17, 2013 the wire from the reverse switch will go through the multifunction control module before it gets to the lamps. i would try breaking into the wire with a 12v feed as far back from the connection to the switch as you can go, quite often find if their is a break in that wire its as it enters the connecting plug. if that doesnt work, if you can tell me exact model, ie engine code..or wether the car has auto lighting or discharge lights or standard system, i'll try and trace the wire in the diagram Quote Link to comment Share on other sites More sharing options...
markw96 Posted December 17, 2013 Author Share Posted December 17, 2013 Its a 2008 1.6 tdci titanium, auto lights and thanks Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 17, 2013 Share Posted December 17, 2013 why not take it back to who did the clutch and get them to fix it since its there mistake Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 17, 2013 Share Posted December 17, 2013 would be the simple answer if problem has been there since clutch job if not. green/ white wire for power to switch green/black to lights from the switch this wire (green/black) goes to fascia fuse box...gets difficult to follow without the car in front of me, but as i understand it its terminal 25 of block D connector to fuse box this then has an internal connection that exits the fuse box at terminal 1 of block F connector and can either be green/black or green/orange this wire then goes directly to rear lights, there is a connection just before the rear lamp but unclear where this is...this connector may be close to rear right lamp which then turns wire to green/orange if wire was green/black before..connects to right hand bulb and bridged to left hand bulb ...(this maybe in reverse order, so connector behind left lamp and bridged to right) Quote Link to comment Share on other sites More sharing options...
markw96 Posted December 18, 2013 Author Share Posted December 18, 2013 What damage could they of done since the clutch job? what should I check for? Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 18, 2013 Share Posted December 18, 2013 if they forgot to disconnect switch before dropping the box, can stretch and break the wire...which is why i suggested breaking into the wire as far back from the switch as you can and put a 12v feed to it to see if that operates the lights...another way of doing it is as follows. youve confirmed you have a 12v feed to switch, so to start with, disconnect the plug, put 12v jumper lead to one side of switch, select reverse with ignition on and check you have 12v coming out of other side. yes, switch ok, then next step no, either switch faulty or box not disengaging the switch...remove switch and test again on the bench to work out which. reconnect switch, use a pin to pierce wire close to switch, check for 12v yes, connection ok...go to next step no, connection bad, either repair connector or replace or cut off and fit individual terminals find the connection as it enters the fuse box...check for 12v... yes, all ok, go to next step no, broken wire, work your way through the wire from fuse box to switch, with the pin till you find the break and bridge a repair wire find the connection that exits the fuse box, check for 12v yes, go to next step no, break or bad connection in box...as this wire doesnt actually go to a fuse you can bridge a repair between the wires and by-pass the box all together....according to the wiring diagram, the wire connects to multifunction module, but the join between the entrance/exit wire is before the multifunction..so in other words, as you dont appear to have any other problems showing, would pay to leave the entrance wire in place and splice into it rather than cut. check for 12v on rear lamps. yes, lamp connection/bulb/earth problem no...work your way back from the lamp to fuse box to find break in wire and bridge repair. Quote Link to comment Share on other sites More sharing options...
markw96 Posted December 23, 2013 Author Share Posted December 23, 2013 Finally got it fixed today. I went to a garage and they found the fault after nearly 2 hours. The problem was a loose connector apparently that plugs into the ecu by the passenger wing. 1 Quote Link to comment Share on other sites More sharing options...
