Transit 110 Tdci 2007
47 replies to this topic
#16 mick85
mick85
  • True Ford Enthusiast
  • 924 posts
Posted 17 December 2013 - 10:31 PM
Yeah I would agree with wase egr prob throw in on that fault an if u remove sensor an check it they come apart ford recommend replace that an imv valve at same time an that fuel rail sensor don't always throw on code or eml but when u replace this u need get pump learned again an u will be prob wanna check for PCM update aswell
Have something to contribute?
#17 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 17 December 2013 - 10:33 PM
its possible as where the oil is leaking it could also suck in air.
think they were metal gaskets so should be able to see if there is a problem...going by the oil leak, you might need to clean all the pipes out too as chances are they will be clogged before the blanking plate.
#18 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 17 December 2013 - 10:36 PM
that rings a bell, mick
take out the pressure sensor it falls apart, and even if it doesnt they suggest new sensor and update....sure that was the 2.2
#19 demikai
demikai
    Member
  • Budding Enthusiast
  • PipPip
  • 23 posts
Sorry last bit of that message confused me a bit when you say replace sensor do you mean maf and somtware update
Makes sense but what do you mean learn pump
#20 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 17 December 2013 - 10:37 PM
Yes mine is 2.2
#21 mick85
mick85
  • 924 posts
Posted 17 December 2013 - 10:45 PM
To be honest can't which member engine size just had that on transit no faults rough idle took out rail sensor broke up replaced with suction control valve(imv valve) on back of injection pump ford recommend but I have often just replaced rail sensor an PCM update
#22 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 17 December 2013 - 10:48 PM
Were will this pressure sensor be located thanks for all help
#23 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 17 December 2013 - 11:03 PM
Would there not be a code if the Imv had failed (broken up
#24 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 17 December 2013 - 11:06 PM
sensor is on end of fuel rail, take off the air filter casing and you will see it
#25 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 17 December 2013 - 11:10 PM
Ok thanks I will check that also thanks a lot for all ideas
#26 mick85
mick85
  • 924 posts
Posted 18 December 2013 - 12:44 AM
U will need stubby 18 or 19 an a hammer to get it off extremely tight an can't fit big spanner in that's if it rear wheeler
#27 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 18 December 2013 - 07:08 AM
No front wheel drive
#28 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 18 December 2013 - 11:56 AM
Right then egr cleaned and back in oil and filter changed and same annoying hunting (revs up and down) only on occasions tho then it's fine then does it again engine managment light still on will I need to get dealer to take it of
#29 mick85
mick85
  • 924 posts
Posted 18 December 2013 - 01:47 PM
What's exact fault is egr still blanked off
#30 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 18 December 2013 - 02:51 PM
Can't read fault my machine won't sync with the van no I took blanking plate out
Average mpg is not as good today as it has been
Not what you're looking for?
