Transit 110 Tdci 2007
47 replies to this topic
#31 wase16ll
wase16ll
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 18 December 2013 - 06:52 PM
egr might have been blanked as it was faulty anyway, might not just be dirty.
or it maybe just code needs clearing.
would also recommend changing the fuel filter if not done so already...if only to just eliminate it
Have something to contribute?
#32 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 18 December 2013 - 06:55 PM
by the way, did you just clean the valve side of the egr, or did you also remove the plastic cover and cleaned the 'gearing' too...if not, do so as they often clog up with gunk too
#33 mick85
mick85
  • 922 posts
Posted 18 December 2013 - 07:00 PM
Yeah would agree with Wase an to be honest when tryin to self diagnose without proper diagnostic u got start with basics rule things out an work way through lot cheaper then goin dealer cause fuel filter prob be first place they start did u check sensor on end of fuel rail see if it's in pieces
#34 demikai
demikai
    Member
  • Budding Enthusiast
  • PipPip
  • 23 posts
Posted 18 December 2013 - 08:05 PM
Hi no changing fuel filter tomorrow there was none in at the shop next to my house so that's tomorrow's job I have not found the sensor yet I will also look for that when I change filter did you say remove the air filter box
#35 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 18 December 2013 - 09:00 PM
for the pressure sensor, yes, its under the air filter box.
#36 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 19 December 2013 - 09:11 AM
Ok thanks going to take a look at that today the engine managment light has now cleared itself no diagnostic equipment used
#37 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 19 December 2013 - 02:35 PM
I did clean all gearing on egr aswell it was surprisingly clean
#38 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 19 December 2013 - 09:17 PM
sounds like the egr is now working as it should, although light is off as its detected all is ok now, the code will still be logged, be worth clearing when you can so doesnt confuse any later issues.
pressure sensor might be your problem if still experiencing the idle issue...worth looking into
#39 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 19 December 2013 - 11:35 PM
I will do thanks for all the help guys the idle seems to be improving maybe it was just coincidence but seemed to do it less as the day went on today so I think the next job is abs and traction control problem both not working locked the brakes today in rain and no abs so any ideas would be welcomed thanks again
#40 mick85
mick85
  • 922 posts
Posted 19 December 2013 - 11:39 PM
Start wit basics fuses an wheel sensors u checked anything yet any lights on dash
#41 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 19 December 2013 - 11:53 PM
as mick suggested, its all you can do without a diagnostic as too many possibles otherwise
with regards to idle, if it seems improved then run it for few days before trying anything else..gives the ecu a chance to relearn and may improve the more you drive it since the engine service/egr clean up
#42 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 20 December 2013 - 06:18 PM
Yeah I removed all sensors today cleaned and re fitted no diffrence the
Idle I can live with for now but the brakes and traction need to be right especially in this weather I'm going to test the sensors to find the damaged ones and replace them hopfully it will be that simple
#43 mick85
mick85
  • 922 posts
Posted 20 December 2013 - 06:42 PM
So wat have u checked on brakes is abs light stayin on dash
#44 demikai
demikai
    Member
  • PipPip
  • 23 posts
Posted 20 December 2013 - 08:48 PM
I have only had time to remove clean and refit abs sensors not had a min to go any further with it yet hoping it's just one gone faulty
#45 mick85
mick85
  • 922 posts
Posted 20 December 2013 - 10:32 PM
Is there a light on dash the light usually comes on if one them broke did u see any potential problems on cleaning
Not what you're looking for?
