fiesta0007 Posted December 21, 2013 Share Posted December 21, 2013 Dear friends My ford fiesta 2011 front fog lights are not working.. do you think the problem was with fuse>? so can you tell me location of fuse? and how do i resolve this? your kind response highly appriciately thankx and regards Quote Link to comment Share on other sites More sharing options...
fiesta0007 Posted December 22, 2013 Author Share Posted December 22, 2013 please help Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 22, 2013 Share Posted December 22, 2013 Dear friends My ford fiesta 2011 front fog lights are not working.. do you think the problem was with fuse>? so can you tell me location of fuse? and how do i resolve this? your kind response highly appriciately thankx and regards Most likely a fuse,Have you had them switched on before? With the engine running I don't have a fiesta or Id tell you the fuse location, Buut check the manual for fuse location. Quote Link to comment Share on other sites More sharing options...
fiesta0007 Posted December 22, 2013 Author Share Posted December 22, 2013 Most likely a fuse, Have you had them switched on before? With the engine running I don't have a fiesta or Id tell you the fuse location, Buut check the manual for fuse location. thank any way Quote Link to comment Share on other sites More sharing options...
potter18 Posted December 22, 2013 Share Posted December 22, 2013 Check fuse ( find location in manual ) it could be the relay to the fog lights fog light switch or a broken wire try the easiest first ( fuse ) then I'm afraid it's a matter of methodically fault finding . If you can get to the fog lights with a multi meter to see if you have power to them then work back from there , hopefully its something simple like a fuse Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted December 22, 2013 Share Posted December 22, 2013 Remember they only work when the main lights are switched on... Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted December 22, 2013 Share Posted December 22, 2013 Run the engine, and put the sidelights on. Then try the fog lights with the sidelights on. Failing that try the fog lights with the engine running and the headlights switched on. Quote Link to comment Share on other sites More sharing options...
fiesta0007 Posted December 22, 2013 Author Share Posted December 22, 2013 can any 1 tell me location of front fog light fuse? is necessary to start the engine or disconnect the battery please help me guys , any electrician please Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted December 22, 2013 Share Posted December 22, 2013 It's fuse number 23 in your engine bay fuse box, see if that's blown. If not try relay number 10, otherwise it's a broken wire or switch. check what potter18 said with voltage at the bulb's then work backwards. Quote Link to comment Share on other sites More sharing options...
fiesta0007 Posted December 22, 2013 Author Share Posted December 22, 2013 guys problem solved thanks for ur valuable commnets thankx u very much friends Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted December 22, 2013 Share Posted December 22, 2013 What was the problem ? :) Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted December 22, 2013 Share Posted December 22, 2013 I'd go with my replies #6 & #7 Quote Link to comment Share on other sites More sharing options...
