slemon123 Posted December 22, 2013 Share Posted December 22, 2013 Hi guys. I need to swap out the pump as it's almost dead. I've poured hot water thinking it might be goo but the pump fails for front and back. Mondeo mk 4 by the way. Thanks. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 22, 2013 Share Posted December 22, 2013 It's usually accessed via the wheel arch. Remove the arch liner and follow the pipes back. The pump should be mounted to the rear of the tank. Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted December 22, 2013 Share Posted December 22, 2013 From under the wheel arch. Take the wheel off and remove the plastic liner and access is easy. Remove the assembly and jet wash it out, I have a compressor which I used to blast out goo from the pump but go carefully. Rinse and re-connect to see if it runs properly and fill 50/50 water and washer fluid. Quote Link to comment Share on other sites More sharing options...
