footydad Posted December 22, 2013 Share Posted December 22, 2013 cant open my door {central locking } , mrk3 mondao tdci 2001 , will lock but not unlock trying to find fuse for alarm , anyone know witch fuse it is ,, hope for some help Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 23, 2013 Share Posted December 23, 2013 if you disconnect the battery then try the key in the door, does it unlock? Quote Link to comment Share on other sites More sharing options...
footydad Posted December 23, 2013 Author Share Posted December 23, 2013 no dosent unlock , , im just thinking i could deactovate alarm system ,if i find correct fuse thanks for help CL Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 24, 2013 Share Posted December 24, 2013 If you disconnected the battery, then turning the key in the barrel should unlock the car. if it doesnt work then its not a central locking issue, its a door lock issue. It sounds like you might have seized locks! Quote Link to comment Share on other sites More sharing options...
footydad Posted December 24, 2013 Author Share Posted December 24, 2013 thanks ive only got one keyhole , needing to deactovate alarm / imoballiser, so i can get the use of car ,to take and get sorted ?? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 26, 2013 Share Posted December 26, 2013 I would start by finding out why the key in the lock doesnt unlock the car. It should do when the battery is disconnected, so this may explain the issues that your seeing, but it could be another factor. Quote Link to comment Share on other sites More sharing options...
Ford Loyalty MK3 Posted December 26, 2013 Share Posted December 26, 2013 You could try and spray some WD-40 on the end of the key, and then try and turn a the key a few times, if that doesn't then it could be your locks thats at fault. Quote Link to comment Share on other sites More sharing options...
