Lock Problems
footydad
cant open my door {central locking } , mrk3 mondao tdci 2001 , will lock but not unlock
trying to find fuse for alarm , anyone know witch fuse it is ,, hope for some help
if you disconnect the battery then try the key in the door, does it unlock?
no dosent unlock , , im just thinking i could deactovate alarm system ,if i find correct fuse
thanks for help CL
If you disconnected the battery, then turning the key in the barrel should unlock the car. if it doesnt work then its not a central locking issue, its a door lock issue. It sounds like you might have seized locks!
thanks
ive only got one keyhole ,
needing to deactovate alarm / imoballiser, so i can get the use of car
,to take and get sorted ??
I would start by finding out why the key in the lock doesnt unlock the car. It should do when the battery is disconnected, so this may explain the issues that your seeing, but it could be another factor.
You could try and spray some WD-40 on the end of the key, and then try and turn a the key a few times, if that doesn't then it could be your locks thats at fault.
