yamaha r1 Posted December 23, 2013 Share Posted December 23, 2013 Hi i have a 99 plate focus left abs front brake comes on while driving and judders to a stop removed fuse drives ok but warning light on any ideas how to fix is it just a cable or more Thanks guys top site Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 23, 2013 Share Posted December 23, 2013 When you remove the fuse, does the car judder at all? it could be a faulty ABS sensor or a damaged loom, but it sounds like the brakes are being applied, so it could also be a piston issue? Quote Link to comment Share on other sites More sharing options...
yamaha r1 Posted December 23, 2013 Author Share Posted December 23, 2013 hi no juddering now the fuse is out someone says clean sensor or replace cable Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 23, 2013 Share Posted December 23, 2013 Yeah, cleaning the sensor will probably be difficult. I tried to remove my sensor and it was welded in place by rust and muck, so if you start the job it may end up a destructive finish! With regards the loom, that is probably the easier part. Ford replaced mine at a cost of about £56 recently, but if your handy with a spanner, you might find that its easier and cheaper to do this yourself. Either way it sounds like there is a fault on that ABS circuit so cleaning / replacing the sensor / loom should resolve the issue. I would say that if you do replace, make sure you do so with a genuine part. Using an odd aftermarket cable could be more trouble than you have right now. Quote Link to comment Share on other sites More sharing options...
